Old 07-18-2004, 06:25 PM   #1 (permalink)
mrcountry's Avatar
Lightbulb Aux Hook Up
Hello Folks, Quick question. I tried to run my laptop through the ( Aux On Stereo) I was going to let the kids watch a dvd on a trip. Thevolume level was so low and I had it cut wide open. Is there anyway to boost the level to where it can be heard. Stupid question, But the kids like there movies
mrcountry is offline   Reply With Quote
Old 07-18-2004, 06:34 PM   #2 (permalink)
Yes. This topic has been lamented and discussed several times in this forum. Do a seach of "aux audio" and it should provide some very good reading as to various solutions.
Basically, it requires adding a line driver module between the AUX IN jack and the input to the radio headunit. The Nissan radio requires two volts peak-to-peak for a 'normal' level at the aux in - most devices with an aux out will provide between 0.3 and 1.0 volt, thus the low level.
Old 07-18-2004, 07:02 PM   #3 (permalink)
mrcountry's Avatar
Thanks
Thanks so much. I looked just did not see. But thanks
Old 07-19-2004, 09:22 AM   #4 (permalink)
sammy sandbag posted pics and info detailing the installation of a PIE brand amp for the AUX input.
Old 07-19-2004, 10:01 AM   #5 (permalink)
llajumpvid's Avatar
I recently found out that on the Armada Bose system that the factory DVD harness can be found just in front of the gear shift. You can't see it but can feel it and unclip it to bring it into view. There is acc power, audio left and right and a FES Enable and Audio on plus the video wires. If you are looking for an additional audio input you can use this. You will still need an inline amp as the volume is low. To activate you can use the rear av swith holding it down for 1.5 seconds. Oh and connect the FES and Audio on wires together. Doing this tricks the HU into thinking the factory DVD is there and on. This will also allow you to select the DVD on the rear controls...still can't select the AUX though.
llajumpvid is offline   Reply With Quote
Old 07-19-2004, 11:28 AM   #6 (permalink)
I bought an amp very similar to Sammy's at my local Radioshack... Here's a link to the RS catalog for it. http://www.radioshack.com/product.as...t%5Fid=33-1109
JAOHN is offline   Reply With Quote
