Old 07-29-2004, 07:49 PM   #1 (permalink)
GETSOMZ28's Avatar
Power cables?
Where is everyone routing their amplifier power cables through the firewall??
Scott
Old 07-29-2004, 07:53 PM   #2 (permalink)
http://www.cardomain.com/item/STRFWB4
Old 07-29-2004, 07:57 PM   #3 (permalink)
smoketitan's Avatar
pull the carpet on the passenger side--you will see the foam--on the foam is the letter N Drill right near the bottom of the N (nearest to the lower LHS of the letter) at with a 1/2 in steel bit ( assuming 4 gage). make sure you check the other side so as not to hit the AC water outlet. if smaller you can run 8 ga through the hood truunk release grommet on the drivers side
one of the members posted pics in his post just do a search for stereo or amp
Old 07-29-2004, 07:59 PM   #4 (permalink)
GETSOMZ28's Avatar
I am actually trying to run (2) 8gauge wires through.
Scott
Old 07-29-2004, 08:14 PM   #5 (permalink)
Why can't you run one bigger wire through the firewall and then split at a fused distribution block? (assuming you are powering 2 amps located reasonably close together) Then also have a fuse or breaker on the big wire near the battery. One bigger wire will likely have less resistance than two smaller wires on a fairly long run (like battery to rear wall of cab)
http://www.powerstream.com/Wire_Size.htm
I calculate a voltage drop of 0.8 V on a 13 ft run of 4 guage wire with a 100 amp load
The drop on a 13 ft run of 8 gauge with a 50 amp load is 1.0
Old 07-29-2004, 09:51 PM   #6 (permalink)
smoketitan's Avatar
yeah run no smaller than 4ga is you have a large amp--just use a ditro block these are really good
http://www.cardomain.com/item/ROCCPPD2
the larger wire will not only allow for more charge to your amp, cleaner sound, less overheating--it will protect your alternator from having to work so hard
make sure you have the proper inline fuse size AT THE BATTERY also for you size amp ( mine if an 80 amp)
