I just grab mine in the upper left hand corner and pull down & out. It just clips on, then you have to remove the wire connectors for the A/C & heat knobs & air bag light. Four screws hold the HU in place. Be real careful not to drop those into oblivion. I use a magnetized screwdriver.
BTW, if you turn the ignition on with the airbag light disconnected, you will get a blinking airbag dash light. Reset instructions are here:
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Don't try to look at your watch or count seconds, as that will mess you up. Here is what worked for me:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
