Old 08-04-2004, 03:21 PM   #1 (permalink)
zpylot's Avatar
GPS Speed Control Wire
I am preparing to install Kenwood DDX7015 and KNA-DV4100 (DVD Navigation System). The 4100 has a white wire labeled "Car Speed Signal Wire". Does anybody here have any idea where on the Titan I can connect that to?
Before you tell me to get the Service Manual. I have it and tried looking at it. I've got some ideas but I would like to know if anybody knows for sure what I can do? That book is not the easiest read.
My Titan is a KC SE with mid-level stereo. No navi, no dvd.
Thanks
"Dogs love trucks."
2004 Nissan Titan SE KC 4x2 Build 04/03/2004, VIN# 540061, Purchased 4/21/04 - Popular with Captains, bedliner, splashguards. Kenwood DDX7015 HU, Westin Oval Tube Steps
2004 Nissan 350Z Roadster Delivered 8/14/03
zpylot is offline   Reply With Quote
Old 08-04-2004, 04:32 PM   #2 (permalink)
GETSOMZ28's Avatar
There is a speed output wire on harness M24 position 29 coming from the stereo.
Scott
Old 08-04-2004, 04:52 PM   #3 (permalink)
zpylot's Avatar
Wow, M24 is connector for the stereo? Sweet.
Thanks
"Dogs love trucks."
Old 08-04-2004, 05:35 PM   #4 (permalink)
GETSOMZ28's Avatar
I think it is for the speed sensitive volume control. You may want to double check that in the service manual.
Scott
Old 08-04-2004, 05:47 PM   #5 (permalink)
kenwood
Zpylot i was lookin at the same receiver and i was wonderin if the monitor goes all the way into the headunit or the whole monitor stays out. its an awesome receiver. Are you having any troubles installing it. What speakers are you using in the door.
Thanx
acontisr is offline   Reply With Quote
Old 08-04-2004, 06:08 PM   #6 (permalink)
zpylot's Avatar
Thanx
The monitor will fix flush with the front face of the dash. It will not stick out. Right now I plan just to use current speakers. If they don't sound good after the initial install then I will dive into replacing them. My first phase is to install the hu, navigation computer and sirius receiver.
No problems yet, I am still planning. The replacement Lid Cluster just came in the mail today. I plan to post photos of the install when I am all done.
"Dogs love trucks."
Old 08-04-2004, 07:07 PM   #7 (permalink)
Connector M24 pin 29 is actually on the combination meter, this would be behind the instrument cluster.
Where you would want to pick it up is on connector M98, pin 24. This plugs into the AV Switch. If you have the PDF manual look at page 26 of the PDF file for the AV section. This is the line that feeds the speed-sensitive-volume control.
Old 08-04-2004, 07:28 PM   #8 (permalink)
GETSOMZ28's Avatar
Thanks for the correction eakes! I was looking at the wrong side of the wiring harness.
Scott
Old 08-04-2004, 08:11 PM   #9 (permalink)
zpylot's Avatar
Thank you eakes, I will give that pin a try.
"Dogs love trucks."
Old 08-08-2004, 03:00 PM   #10 (permalink)
zpylot's Avatar
Yep, that was it. Now the GPS knows how fast the truck is traveling. I am not sure what they use it for but when the vehicle is moving some of the Navi Setup options are grayed out.
So now I need some more help. Where on the Titan would I plug in the Parking Brake Sensor wire. I need to plug this green wire into the parking brake so I can watch video. When playing a DVD I hear the audio but there is no video. I assume it's because this wire is not connected. Again I cannot make heads or tails out of the service manual. Maybe somebody can tell me what page to look on for what I need.
Thanks again.
"Dogs love trucks."
Old 08-08-2004, 04:48 PM   #11 (permalink)
Connect the green wire to ground (the chassis) and you can watch video. They direct you to connect it to the parking brake so the video will only work when you are parked.
If you want to have control of when the video is on, get a normally open toggle switch at Radio Shack. Connect one side to ground and the other to the green wire. When the switch contacts are closed the video works, if they are open there will be no video.
Old 08-08-2004, 05:27 PM   #12 (permalink)
I have been looking at that same unit, let me know how it all works out! best of luck!!
scubakleev is offline   Reply With Quote
