Old 08-04-2004, 08:38 PM   #1 (permalink)
mikegronholz's Avatar
My Audio Install ... Truely 1 of a kind !!!
Still working on it, but you guys will get the idea !!! Here is the setup ...
Alpine 9835
JL Audio XR650-CSi (Front)
JL Audio 650CXi (Rear)
JL Audio 300/4
JL Audio 500/1
2 JL Audio 10W3v2
Custom fiberglass and 1" MDF box under rear seat
Custom dash kit (I can make more if any of you want one)
Alpine XM
Alpine 12 Disc Changer
Alpine 7" monitor (removed from its own drop down and custom mounted in ceiling console) - in progress
Alpine 5205 DVD - in progress .... going in 2nd DIN slot
Amps are under the front seats and have trays built on top of them for cooling fans, the crossovers and the CD Changer. XM is behind the rear seat.
Here are some pics of the progress ...
my-audio-install-truely-1-kind-dsc00060.jpg  my-audio-install-truely-1-kind-dsc00061.jpg  my-audio-install-truely-1-kind-dsc00063.jpg  my-audio-install-truely-1-kind-dsc00064.jpg  my-audio-install-truely-1-kind-dsc00065.jpg
mikegronholz is offline   Reply With Quote
Old 08-04-2004, 08:51 PM   #2 (permalink)
GETSOMZ28's Avatar
Looking good!
Scott
Old 08-04-2004, 09:58 PM   #3 (permalink)
Send a message via AIM to KY TITAN
very nice! you do all the work yourself?
Finally Arrived:
2004 Nissan Titan 4x4 KC SE - Black
Off Road with E-Locker
Big Tow
Captains Chairs with Rockford Fosgate
Utility Bed Package
Bed Extender
MY TRUCK IS HERE!!!!!!
KY TITAN is offline   Reply With Quote
Old 08-06-2004, 11:35 AM   #4 (permalink)
FXR
FXR's Avatar
Nice install!
I am runnig that same amp on my seperates.
I ended up running the front dash speakers off of the rear output of the deck and the front and rear seperates off of the rear out RCA's. You can then fade front to rear to add fill up high from the dash 1-1/2".
I am running the following:
Pioneer DEHP-9300
JL 300/4
USA-700T
2 Diamond MacDaddy 10's
6-1/2" Diamond Hex Seperates, Front
6-1/2" Diamond Coax, Rear
FXR is offline   Reply With Quote
Old 08-06-2004, 11:48 AM   #5 (permalink)
dooboy2112's Avatar
That's nice good work.
Titan page
04 Smoke KC SE 4x4
Offroad package
Big Tow
Utility Bed
K&N Aircharger
dooboy2112 is offline   Reply With Quote
Old 08-06-2004, 10:20 PM   #6 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Nice amps, good quality.
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 08-07-2004, 08:10 PM   #7 (permalink)
Send a message via AIM to 04TitanXECC Send a message via MSN to 04TitanXECC Send a message via Yahoo to 04TitanXECC
That's a nice set up. Me personally i like all the Diamond Audio stuff. I had a JL 12W7 powered by a MTX 81000D and that wasnt bad but the sound quality wasnt there. Now, in the new Titan i'm going with all Diamond Audio equiptment. Im going with TDX 6 1/2 components with a silk tweeter up front. In back im going with M6 6 1/2 component with an aluminum tweeter, with all of it bi-amper with a pair of D5 600.4 amps. And for subs im going with a pair of M6 Mach II 10D4's powered by a D5 1200.1. And for a head unit im going with an Eclipse CD8454 so i can get all the time alignment with a professional set up.
04TitanXECC is offline   Reply With Quote
Old 08-07-2004, 08:47 PM   #8 (permalink)
Send a message via AIM to MaxPowers
Wow, sounds expensive but would sound great too.
MaxPowers is offline   Reply With Quote
Old 08-08-2004, 10:28 AM   #9 (permalink)
Not as expensive as you think. For everything except the HU its just over $2000. And im going to do most of the building and install so thats where im saving all the money. The hardest part of it all is going to be the time alignment and bi-amping the components, which a buddy of mine is going to do it all professionally. And building an enclosure for the subs, which isnt really hard its just time consuming. All in all its gonna cast me about $2800 and a case of beer to do everything.
Old 08-10-2004, 05:23 AM   #10 (permalink)
I'm considering the same subs and sub amp. How much air space are you getting on each sub...? Is it LOUD...?
Thanks,
Josh
JoshJam is offline   Reply With Quote
Old 08-10-2004, 08:30 AM   #11 (permalink)
Thanks,
Josh
Getting right at .8 per ... and is it LOUD ... it can be
Old 08-10-2004, 08:43 AM   #12 (permalink)
Because of the similarity in our systems, I'm going to bother you some more. (I'll be running the same amp on the highs as well)
1)Are you running a capacitor...?
2)What gauge wire did you run back...? What gauge to the amps...?
3)Did you run new speaker wire for the door speakers, or tap into the factory wires...?
Thanks a ton...?
J
Old 08-10-2004, 08:47 AM   #13 (permalink)
Im running a Directed 5F cap just for the subs and thats it. I ran 1/0 and split it to 4ga and ran that to the amps. And i never use factory wires, they are too small, i always replace factory wires.
04 Titan XE CC 2WD Born July 31 2004
Eclipse CD8454
JL12w7
MTX 81000D amp
glasspack true duals w/split rear exit
Ventshade bug deflector
***not any more***
2005 Chevy Silverado 2500HD LT SB CC
Duramax
every option polible
Old 08-10-2004, 09:19 PM   #14 (permalink)
Thanks a ton...?
J
No cap. You have to REALLY let the subs thump to get any light dimming effect !!!
Ran 4 gauge to each amp, 12ga to the fronts, used the factory for the rears (to much of a pain to use the POS hose Nissan gave us) and 8ga to the subs. All JL wire.
It would have been nice to run wire to the rears, but Nissan dropped the ball on wire loom to the rear doors on the KC !!!
Old 08-10-2004, 11:00 PM   #15 (permalink)
smoketitan's Avatar
how did you all run wire through the front doors through that rubber housing in the doors?? I fiugred I had to take the dash off--please do tell d loved to not have to splice the thin stock wire
