Old 08-08-2004, 02:04 PM   #1 (permalink)
tire sizes?
i have a 2wheel drive titan and iam wanting to put 20 inch wheels on with street tires what is the biggest tire size i can put? the wider the better
bigd2115 is offline   Reply With Quote
Old 08-08-2004, 03:02 PM   #2 (permalink)
mikeody2003's Avatar
I have 22 with kumho 305x45x22 they ride like stock even better the stock IMO and there is no rubbing of any kind.....I dont know on the 20 but hop this helps
mikeody2003 is offline   Reply With Quote
Old 08-08-2004, 10:36 PM   #3 (permalink)
TIsTAN's Avatar
good start but knowing the width and offset would help more.
PRG'd!!! Also a member of the Saggy Stillen Grill club!
TIsTAN is offline   Reply With Quote
Old 08-08-2004, 10:49 PM   #4 (permalink)
the width of that tire is 305mm... Can't tell you what his offset is, lol.
Old 08-08-2004, 10:54 PM   #5 (permalink)
DallasTitan's Avatar
Well, you have the same question I've been asking myself and here's what I've found so far:
P305/50-R20's are $823.00 installed at Discount Tire.
They may require the DayStar 2.5" lift since they are 12" wide tires.
To answer your width question, yes they are wider(and only 0.6" shorter than the stock: 32.61 vs. 32.01 so you won't lose any height.
By comparison, if you had chosen to go with the LT305/55-R20 size,
you'd gain a little height, but the price jumps to : $1375.00 installed!
I guess in this case the choice is clear.
BTW, TisTAN is right, make sure your offset is not too far away from the stock +25mm
or you could just have them put one on to see if it's right for your truck.
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
DallasTitan is offline   Reply With Quote
Old 08-09-2004, 08:29 AM   #6 (permalink)
You can put a 275-55-20 on with out any prob. same size that is on the ram 20s. a 305-50-20 will also fit but i do nost know if tire will fit under the truck? It will depend on the width of the rim and the backspacing.
04 Red Brawn KC SE SOLD!!!!!!!
01 Lightning # 1916
391hp/500tq
braun04 is offline   Reply With Quote
