Old 08-09-2004, 06:02 PM   #1 (permalink)
Rear AUX Setting in Armada/Titan Answer/Update
I may have an answer to everyones question as to the AUX setting in the rear audio controls. I sat in the back of mine with a set of headphones and mine switches to AUX. It plays the Factory Sirius Satellite I had installed. Thus one can be listening to Sirius up front and you can listen to any of the other choices in the back.. Vice versa, one can be listening to a CD/AM/FM up front and anyone in the back can be listening to anything else including Sirius. One thing I did notice was if the Front was listening to Sirius, you could not change the channel on Sirius in the back unless it changed the front to. However you could change it independently if the front was listening to FM or something else. I am going to wire into the factory DVD lines to attach my factory DVD and then should be able to have full control over the rear Audion controls.
kthrash is offline   Reply With Quote
