Old 08-10-2004, 06:38 PM   #1 (permalink)
Under Body Lighting
Has anybody put an underbody light kit on the titan? Wondering where to get the power from? Is there anywhere in the fuse box that i can take power off for the lighting or shuld i run a direct line from battery?
acontisr is offline   Reply With Quote
Old 08-10-2004, 06:45 PM   #2 (permalink)
dooboy2112's Avatar
Why do you want to turn your truck into a disco machine?
Titan page
04 Smoke KC SE 4x4
Offroad package
Big Tow
Utility Bed
K&N Aircharger
dooboy2112 is offline   Reply With Quote
Old 08-10-2004, 07:01 PM   #3 (permalink)
SoCalBluetooth's Avatar
This is just my humble opinion. If I were to install a lighting kit I would take power directly from the battery and install a inline fuse 12" from the battery connection. Alternately you could tap into the constant 12 volts on the ignition switch wiring harness and again put a inline fuse no further than 12" from that connection. I assume you will want to mount a seperate switch for turning the lighting on & off. If so then I would order a factory switch like the tow mode switch and install it in one of your blank switch spots. You can simple rub the words tow mode off of the front of the switch. It would then look very custom. There is a rubber grommet in the firewall just above where the hood release cable runs thru the firewall. This can be used to run your wiring in& out of the cab. Also it's always good pratice to use electrical tape and wire harness loom to protect wiring and preventing shorts as well as opens. Hope you find some of this useful.
Steve - "A Rumor Is Nothing More Than An Unconfirmed Fact"
20" Boyds, Running Boards & E&G Classics Grille, Pace Edwards Electric Tonneau,
Clifford RSX 3.5 Alarm / Remote Start, Sirius Radio, Drop-in K&N, Factory Hood Protector, Carbon Fiber Dash, Backup Warning Sensor.
Future Mods - Dual Exhaust, Headers, SuperCharger!!!
SoCalBluetooth is offline   Reply With Quote
Old 08-10-2004, 08:01 PM   #4 (permalink)
radiokid's Avatar
Didn't Paris and Nicole get busted for that?
2007 Deep Water Blue KC SE 4WD
STILLEN BIG BRAKES
radiokid is offline   Reply With Quote
Old 08-10-2004, 11:20 PM   #5 (permalink)
No Titan disco system would be complete unless you used one of the overhead compartments for a deployable sparkling disco ball!
Old 08-11-2004, 02:49 PM   #6 (permalink)
Thanks everybody for your help just playing around with some lighting.
Inline fuse should be 12 ' from switch or actual connection to 12v
Old 08-11-2004, 03:22 PM   #7 (permalink)
TNTITAN's Avatar
Lets hope he is putting it under there to assist in trailside repairs at night..........
Matt
2004 Silverado Z71
Knoxville, TN
TNTITAN is offline   Reply With Quote
Old 08-11-2004, 06:29 PM   #8 (permalink)
Go 12" (inches) from your 12v supply. all wiring past the fuse will be protected.
