Front door speakers are 6x9, rear door speakers are 6.5 inch. Pull the cover off the dash tweeter and you can see the size for yourself.
The rear door speakers have a mounting bracket built with the speaker. To replace those you will need to build a mounting bracket - MDF board works well.
If your plan is to replace only the speakers and not the HU/amp, then I would advise against changing the speakers. First, it will not sound any better and second, you stand a very good chance of blowing the new speakers. The existing amp is very underpowered, as you increase the volume to get more/better sound the amplifier is driven into overload and begins to flattop. This effectively creates squarewaves into the speakers on certain musical passages. A squarewave is (for short periods of time) nothing but a DC voltage. DC volatge is not good for a speaker - too much, too often and the speaker is not a speaker anymore.
