Originally Posted by kjc609
I'm using an add on system to the oem keyless, I need to know where to get the negative pulse signal for the start function, Its either the lock or unlock button. Also, do I need a relay in there for the neg pulse? I cant find it. One more, for the bypass box, how do you wrap the wire around the ignition to give it the signal? Please help, my truck is down until I get thing running.
Hope this helps!
Start:
Brown
IGNITION SWITCH HARNESS
2nd starter
Lt.Green
relay Diagram
Starter Kill:
same as starter wire
RElay diagram
1st Ignition:
Black/Red
2nd ignition:
relay Diagram
Accessory #1
Red
Accessory #2
purple
relay Diagram
Parking Lights (+):
Red/Blue
located at the At dimmer switch
Parking Lights (-):
Factory Alarm Arm
Arms with lock wire
Factory Alarm DISARM
Disarms with unlock wire
Hood Pin
Hatch or trunk pin
trunk release:
Notes:
keyless Bypass Module: NO
Bypass Module Number:tbkII
Door Lock Interface model:na
nissan titan 2004
Constant +12 Volts:
Dark Green
Brake Light:
Red/Green (+)
brake pedal switch
door trigger:
see notes * (-)
OEM Horn:
Red/White (-)
located at the steering column harness
Power Lock:
Blue (-)
At switch inside driver's door
You must run wires into the doors to connect to these wires. The first pulse on the RED will disarm and a double pulse will unlock the doors.
Power Unlock:
Red (-)
Headlights:
see notes on rap
speed sense:
Tach Signal:
(AC)
This vehicle has independent coils, there are three wires per coil, White/Blue, Black and the third is the tach signal wire. Or you can use the pposite of White on the injectors
rap shutdown :
Lt.Blue
This vehicle is equipped with automatic headlights that will stay on after a remote shutdown.you must pulse the drivers doorpin wire to shut the lights off. Drivers doorpin is Lt.Blue at B.C.M. on right side of steering column
Notes:
· Left Front door trigger - LIGHT BLUE
· Right Front door trigger - RED/BLUE
· Left Rear door trigger - RED/ORange
· Right Rear door trigger - GRAY
· REAR DOOR trigger - RED
All wires located IN the bcm ON TOP OF GAS PEDAL. Diode isolate each
Front Stage Amp: Mmats SQ2175
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
Esoteric:
"Understood by and meant for
a select few."
