Old 10-04-2004, 01:48 PM   #1 (permalink)
cshepherd's Avatar
Double din opening?
I want to do an audio upgrade on my Titan but I plan on using a single din receiver. The faceplate that is available is a double din. What have you single din-ers used to fill up the open space with? Is there a coin tray or insert available?
Thanks!
4x4 SE Crew Cab
Deepwater Blue
Pop, Utility, Off Road and Big Tow Packages
Wade OEM Hood Deflector
cshepherd is offline   Reply With Quote
Old 10-04-2004, 02:05 PM   #2 (permalink)
WazzuCoug's Avatar
Send a message via MSN to WazzuCoug
you can get a standard nissan dash kit at your local stereo shop. This fills the extra din with a small pocket type recess. That is what I did when I installed my Alpine. Also make sure you use a wire harness as well with the install. It will save you lots of time, and allow you to easily remove your radio if you sell your truck.
WazzuCoug is offline   Reply With Quote
Old 10-04-2004, 02:06 PM   #3 (permalink)
Supporting Vendor (Gold)
You can get the metra kit for 1995 Nissan's and up..This will fit just fine. You can get them from crutchfield or best buy/circuit city.
Headunit: Kenwood Execlon DDX812
Front Stage Amp: Mmats SQ2175
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 10-04-2004, 02:19 PM   #4 (permalink)
cshepherd's Avatar
Thanks guys for the info! Searching Crutchfield now for the metra kit, but coming up dry. Do you have a part #?
4x4 SE Crew Cab
Deepwater Blue
Old 10-04-2004, 02:52 PM   #5 (permalink)
http://www.crutchfield.com/S-2kgO8cb...&avf=N&search=
a select few."
Old 10-04-2004, 03:35 PM   #6 (permalink)
cshepherd's Avatar
Thanks LK!
4x4 SE Crew Cab
Deepwater Blue
Old 10-04-2004, 03:40 PM   #7 (permalink)
You bet....Please post pictures of install when your done!!!!!!
a select few."
