LPF and HPF settings
Do you think this will work. Record a 80hz-100hz tone for setting the LPF using sine waves recorded at 0db and then set your amp crossover frequency down then put cd in that you made turn frequency up until you hear the tone. Do you think this would work. I would think this would me the most accurate way to set your LPF or HPF..
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
