Old 10-21-2004, 01:08 PM   #1 (permalink)
Antenna placement?
Where are you placing your satellite antennas?
virus is offline   Reply With Quote
Old 10-21-2004, 01:54 PM   #2 (permalink)
While I'm asking, how about placement of your Audiovox PNP2 units? I'm picking up a PNP3 tonight.
Old 10-21-2004, 02:44 PM   #3 (permalink)
I put the antenna for my XM just above the drivers side top of the windshield. I ran the wire straight down through the existing windshield rubber molding, through the body line where the hood meets the fender and then through the rubber seal that feeds just behind the firewall. Then I just zip-tied the wire to existing wires and viola..done. Took about 5 minutes total, the hardest part is feeding the wire through the rubber seal and behind the dash, you really have to reach your hand up in there to get it through. Good luck.
2004 Titan CC LE 2WD, White
Lots of mods....but not the good kind....
1. Brakes Resurfaced twice
2. Rotors and pads replaced
3. Wheels and tires balanced five times
4. Horn Replaced
5. Radio Replaced
6. Fuel Tank on order for spilling EVERY time
7. Back of drivers seat stitching came apart
8. Drivers seat broken and leaning to the right
9. Rear seat belts replaced
10. Radiator smell
11. One tire replaced
And yes, I'm a complainer..deal with it, that's what forum's are for.
TITANLECC is offline   Reply With Quote
Old 10-21-2004, 03:55 PM   #4 (permalink)
PHX_TITAN's Avatar
For my SIRIUS, the antenna is roof mounted near my 3rd brake light...
Rob
2004 SE Crew Cab
- 4x2
- Big Tow
- A.R.E. Tonneau
- Borla Dual Exhaust
- Westin Nerf Bars
- SIRIUS Satellite Radio
PHX_TITAN is offline   Reply With Quote
Old 10-21-2004, 04:47 PM   #5 (permalink)
40-Dan's Avatar
just north of the 3rd brake light.
Dan
Smoke '04 Titan LE 4x4 CC
Off Road Pkg w/ VDC, Big Tow, Sunroof, DVD
40-Dan is offline   Reply With Quote
Old 10-21-2004, 06:01 PM   #6 (permalink)
What units did you Sirius guys buy? I just bought the Audiovox PNP3, but it looks absolutely identical to the Sportster front, back and connections. The Sportsters plastic casing looks like it's almost an exact match for the dash plastic in the Titan.
Old 10-21-2004, 06:20 PM   #7 (permalink)
gedunk's Avatar
My Sirius antenna is mounted out through the 3rd brake light assembly on the roof. VERY easy to do. My tuner is the Clarion OEM Nissan tuner.
'08 Blizzard TITAN LE Crew Cab LWB 4x2
Big Tow
XM SAT
Floor Mats
Window Tint
Factory Splash Guards
Sliding Toolbox
OEM Hood Protector
20" MB Wheels Gunner 6
20" Pirelli Scorpion ATR 275/55/20
***Previous - '04 TITAN LE KC 4x2***
gedunk is offline   Reply With Quote
Old 10-21-2004, 06:42 PM   #8 (permalink)
Had to share space with my CB. I opted to go with the tall XM antenna. Routed everything through the 3rd light.
Born 6/04 Silver LE KC 4x4 Big Tow,Side Air Bags,Mats,SL Extender,SL Divider,Truxedo Low Pro,Nissan XM Sat,Weatherflectors
Stitch is offline   Reply With Quote
Old 11-08-2004, 03:29 PM   #9 (permalink)
dman's Avatar
XM - Antenna placed on dash as far forward as possible and centered from left to right.
dman is offline   Reply With Quote
