Originally Posted by bestatchess
Several people are having problems with ground loop/alternator noise in connection with stereo installs. Assuming you don't have this problem, would you mind answering:
1. Where & how is everything grounded?
All of the amplifiers are grounded to a single location on the chassis using 0 awg wire. You have to be sure to take all of the paint off of the grounding location. All peripheral items are grounded to the factory radio grounding point and to the chassis of the radio.
2. Were any ground loop isolators used?
Nope. There was no noise in the system. Typically a GLI is nothing more than a bandaid for another problem anyway.
3. Did you upgrade the stock battery/alternator ground cable?
No need to upgrade the alternator. We used the big capacitor instead. It's 40 farad and keeps the voltage pretty consistently at 13.8V with the engine running and stereo at full tilt.
