Old 10-24-2004, 04:12 PM   #1 (permalink)
Question Questions about putting in new speakers
I have a set of speakers ive installed, but now im starting to question if I did it properly.
I have a KC, without RF.....had a indash 6 disk, replaced it with an aftermarket radio. I am using the pre-amp in the radio (not an external amp)
I used the factory wiring. Should I run all new wires? I assume there is a cross over (probably a real crappy one) thats a split between the front dash and the front door speakers. How should I wire the front door speakers? If I should use the factory wiring, what is the colors for +/- ? It's not marked anywhere for the front speakers.
Any prompt responce would be greatly appreciated since I have the front door panels off right now.
Thanks,
Beaker
Beaker is offline   Reply With Quote
Old 10-24-2004, 06:32 PM   #2 (permalink)
now i cant get my passanger side window to roll up.....its not the usual problem where it just clunks....and goes back down.......its like the motor isnt getting power at all.....i checked all the fuses....im kinda stumped at this point...
Old 10-24-2004, 08:03 PM   #3 (permalink)
Do you still have the door panels off? If so, the switches need to be plugged in to complete the circuit!!
04crew is offline   Reply With Quote
Old 10-24-2004, 08:28 PM   #4 (permalink)
yes, both switches are on...
the window on the drives side works....both door locks work on both sides from both switches......just the passanger side window is dead
i took it apart and took out the motor and pushed up the window for now...
i want to take it into the dealer and have it fixed under warrenty. but ive already messed with it (took out the motor to manually push it up) ....i know the dealer will try to use that against me.
this is really bummin me out....this truck has 7k miles on it.....the windows dont roll up on the first try 75% of the time....now the passanger side window is dead.....my rotors are warped BAD.....i love this truck, but its starting to make me hate it......too many problems way too soon.
Old 10-24-2004, 08:48 PM   #5 (permalink)
I would pull new wires for the speakers. I think the stock wires are about the same diameter as a blond angel's hair.
Old 10-24-2004, 09:03 PM   #6 (permalink)
I personnally wouldn't waste my time with the speaker wires. Your still using your factory headunit. To me thats like using a higher octane gas because you put tires on with a higher speed rating. Now, if yoiu decide to build a system, you will benefit running a better wire.
Old 10-25-2004, 08:51 AM   #7 (permalink)
I am not using my stock head unit though.
Old 10-25-2004, 09:24 AM   #8 (permalink)
Check this out:
http://www.proav.de/index.html?http&...akercable.html
Old 10-25-2004, 08:25 PM   #9 (permalink)
so ...can anyone answer my question? I need to know which wires are which in the front doors......(pos/Neg)...
Old 10-25-2004, 08:34 PM   #10 (permalink)
Supporting Vendor (Gold)
Just use a 9volt battery to test the woofer that will tell you what's positive and what's negative. If you hook the battery to the terminals if the woofer pushes out that's postive if the woofer sucks inward that's negative...
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 10-26-2004, 05:24 AM   #11 (permalink)
Front Left Door and tweet: L/R (-) and L/W (+)
Front Right Door and tweet: L/B (-) and W/B (+)
