Old 10-24-2004, 07:41 PM   #1 (permalink)
Supporting Vendor (Gold)
Tomorrow's project!
Going to install a better qaulity 1/0 gauge power wire and ground (more wire strands). I will attempt to install 1/0 gauge ground wire for battery and frame to help with any flickering light issue..
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 10-24-2004, 07:59 PM   #2 (permalink)
smoketitan's Avatar
dude I still cant find the grommet--LOL!!!! IM running mine on tuesday once I go to this welding shop to get some welding cable
Old 10-24-2004, 08:02 PM   #3 (permalink)
Grommet LOL!!!! Cool, I'm hoping to totally get rid of the lighting issue..
a select few."
Old 10-25-2004, 12:09 AM   #4 (permalink)
smoketitan's Avatar
so lizard your lights dim under heavy bass notes I assume?? where are you running your 1/0 wire at? I drilled on the passenger side for my 4 ga, so I may just buy a larger bit to fit the 1ga through it..
Old 10-25-2004, 12:13 AM   #5 (permalink)
I will be grounding to the existing grounds on the battery to the frame and engine. I figure I will start there first.. Yes, I get dimming lights very slight but I do when I have heavy bass notes.
a select few."
Old 10-25-2004, 12:20 AM   #6 (permalink)
smoketitan's Avatar
so you are doing the big three also--yep that is my next trick also
I swear you would think witha 130a alternator,and a 770cc battery there wouldnt be any of these issues.
where are you getting your wire and ring terminals from??
I get mine from knuconceptz.com but I am going to try some welding 2/0 cable for my grounds and power as I can get it local for less than 1.70/ft and supposedly it is better to work with than standard audio power wire-well see though
Old 10-25-2004, 12:25 AM   #7 (permalink)
I got my stuff from Crutchfield came as a kit. They say the more strands of wire the better and this stuff I got has alot! 4300 strands... OH YEAH!
http://www.crutchfield.com/S-bzgfeCb...nfo&i=211PS00R
a select few."
Old 10-25-2004, 12:26 AM   #8 (permalink)
The fuse holder is HUGE to say the least!! I think it's got to be around 8inches long.
a select few."
Old 10-25-2004, 12:37 AM   #9 (permalink)
smoketitan's Avatar
fyi the knuconceptz is over 5000 --you may want to return it. the added wire only makes it more flexible not more conductive
not a bad price for precrimped lines though. the knu set is like 69 I think plus 7 shipping, but you have to crimp your own lines
my current power line is 20ft,and I just make it to the back, is 18 ft long enough?? maybe I have routed wrong
and to do the big three you are going to need abother 10ft or so, at least that is waht I calculated--but that doesnt mean a whole lot as I tend to over estimate.
Old 10-25-2004, 12:41 AM   #10 (permalink)
I always thought and heard the more wires the more current flow that's why high current lines have so many strands and are huge. I already ran the power wire and have it wrapped under hood for tomorrow.. It's more then long enough, I will run it to my distribution block where I have 4gauge running to the amps and cap...
a select few."
Old 10-25-2004, 12:46 AM   #11 (permalink)
smoketitan's Avatar
so where did you go through the firewall I am dying to know??
Old 10-25-2004, 12:51 AM   #12 (permalink)
Same location as before just drilled it out bigger 3/4". Went just next to the hood latch cable where there was already a hole with a rubber grommet covering it up. Isn't the bigger the wire/more strands the more current the amp can draw? This is what I have always known and found on audio websites.
a select few."
Old 10-25-2004, 12:59 AM   #13 (permalink)
smoketitan's Avatar
no you are right on the more strands more current line--just saying that while the knu wire had more strands than the stringer--once it is labeled 1/0 ga ( based upon it standardized current capacity) more strands will only make it more flexible--sorry for the lack of clarity
cool one runnign the wire I guess I have to go buya new drill bit
Old 10-25-2004, 01:03 AM   #14 (permalink)
If you have a reamer that will work..It's what I used.
a select few."
Old 10-25-2004, 04:53 PM   #15 (permalink)
I installed the new power cable today and ran out of time for the ground upgrade! Will start that this week sometime and hopefully will go as smooth as today went!
a select few."
