Old 10-25-2004, 05:19 PM   #1 (permalink)
setitan's Avatar
? about Midline Stereo system
Do I have an amp on the midline 6 disc stereo? If so can I put an LOC before the amp that will jack into the factory wiring harness?
04 Titan SE Crew cab 4X4, Born 6/04 Purchased 8/04
White, W/Graphite, SE Pop Pwr Capt.
Utility Bed & Sliding Bed Ext, Splash.
Mods:: Wade in channel Vent Visors, Front Windows Tinted, Banks Monster Exhaust,
Chrome Westin Oval Tube Steps, Volant CAI, Stainless Tube Grill, A.R.E. Z Series Cap,
22" Boss 313's w/Falken S/TZ-04 305/45-22 Tires
setitan is offline   Reply With Quote
Old 10-25-2004, 05:24 PM   #2 (permalink)
Supporting Vendor (Gold)
I don't believe it has a external amp like the RF. You would want to install the LOC right after the radio.
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 10-25-2004, 05:44 PM   #3 (permalink)
setitan's Avatar
Does anyone make a wiring harness adapter that I can wire the LOC to so I dont have to cut the factory harness?
Who makes the best LOC for this application, and do they make one that can adapt to 6 channels, Front, Rear & Sub ?
Thanks in advance for your help.
Old 10-25-2004, 06:03 PM   #4 (permalink)
Yeah, Metra and Scosche makes wiring adapters.
LOC
http://www.crutchfield.com/S-QXuUBZG...+out+converter
LOC
http://www.stingerelectronics.com/we...lectronics.asp
Wiring harness
http://www.crutchfield.com/S-QXuUBZG...00&I=120707550
a select few."
Old 10-25-2004, 06:43 PM   #5 (permalink)
Scosche makes NN03RB (connectors which plug into the HU) and NN03 (I think that is the number) plugs into the factory wiring harness. You solder the appropriate wires to your LOC and to make a jumper from the NN03RB to the NN03 to provide power, etc. to the HU, and then you plug it together.
Check the photo in post #13 in this thread:
RF speaker upgrade
That is the RF HU, but I think the same would apply to the midline.
And then you would have to make connections from your amp(s) to the speaker wires (or pull new wires).
I don't think you need a six channel LOC as you don't have six channels out of the HU. I used a 4 x 100 amp connected to a 4 channel LOC, and then low-passed the signal thru put from the 4x100 amp to the sub through a second amp.
Old 10-25-2004, 06:53 PM   #6 (permalink)
Originally Posted by lizardking
That wiring harness is for use with aftermarket head units that come with their own wire harness. It won't plug into the OEM head unit. You need Scosche NN03RB to plug into the OEM head unit. The Scosche NN03RB takes the place of the wire harness that would come with the aftermarket head unit.
Old 10-25-2004, 07:00 PM   #7 (permalink)
I posted the wrong one...Metra makes one I can't remember the number.
a select few."
Old 10-25-2004, 07:03 PM   #8 (permalink)
I believe it's this one.
http://www.metraonline.com/product.aspx?sku=71-7550
a select few."
Old 10-25-2004, 07:50 PM   #9 (permalink)
Yes, that looks like the connectors that plug into the Nissan HU (equivalent to Scosche NN03RB).
