Old 10-29-2004, 01:00 PM   #1 (permalink)
igotatitan's Avatar
PrerunnerGreg's Leveler Kit = Bigger Tires?
I've got a XE CC w/ Off Road Pkg. With PrerunnerGreg's leveler kit installed, what is the max tire size you can run without rubbing?
2004 XE CC OR
Radiant Silver
Born 8/04
igotatitan is offline   Reply With Quote
Old 11-01-2004, 12:27 PM   #2 (permalink)
Send a message via AIM to Batman229
I've heard 35x12.5
Batman229 is offline   Reply With Quote
Old 11-01-2004, 01:11 PM   #3 (permalink)
Send a message via AIM to 1badz06 Send a message via Yahoo to 1badz06
I havent herd that.... 35 12.50s would really be nice, hope someone confirms this.
1badz06 is offline   Reply With Quote
Old 11-01-2004, 01:24 PM   #4 (permalink)
Question Nissan Oil?
I was just curious if anyone knew who makes the oil for nissan or any opinons for this oil. I was considering just sticking with oil changes at the dealer but not sure about the oil they use.
rrhanck78 is offline   Reply With Quote
Old 11-01-2004, 06:15 PM   #5 (permalink)
Mike H.'s Avatar
Originally Posted by Batman229
I've heard 35x12.5
I would say no way. My Nittos are 33.19" x 12.13" on 8" wide factory backspaced (5") wheels. Sitting still, there is a point where the outside tread corner is less than 1" from making contact with the inside rear of the well. This is at about 1/2 of full stearing range. It would be extremely close if I hit a bump at that point. Using less than a 5" backspace, or a wider wheel, or both, would make it even closer.
Putting a 35" on mine would make contact at that point of a turn.
Mod links (clickable):
Old 11-02-2004, 03:01 AM   #6 (permalink)
Bob
Just finished the lift kit...325/65/18 35" inch tires on stock wheels
Bob is offline   Reply With Quote
