I have a Roady 2 that eventually I would like to hard wire into the back of the HU (if the connection exists which I assume it does as I have the SAT button on my dash). Right now it is plugged into the AUX port via a plug bought at Radio Shack (not L shaped). As far as sound difference, I don't know, but it does sound CD quality out of the AUX port
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
TomTom One 125 GPS
Born On Date - 03/19/04
Adopted On Date - 06/28/04
I have my Sirius plug-and-play tuner installed in my truck and I have been using the aux. input in the dash. I initially tried using the FM modulator, but I didn't like the way it sounded. Hard wiring is definitely the way to go for the best sound quality.
The only problem that I have with the aux. input is the volume level. It seems that when using the input jack, the volume level is roughly half what it is using the FM modulator. Personally, I don't mind giving up the ability to play at full volume as long as I can keep the sound quality as high as possible. It's difficult to tell my Sirius tuner from my CD player at the lower volume levels.
Well I got it installed. I used an L adapter for the back with an atenuator (spelling?) and plugged it into the AUX port. This just isn't the way to go. The AUX port does sound clean, but even when all volumes set to full level, it's still to low. I am going to use the Audiovox FM Hardwire module available at Circuit City. It will give the same volume characteristics of FM and sound almost as clean as the AUX. Basically when it detects that the PNP unit is turned on, it will deactivate the cars outside antenna.
I'm going to have to take pics. It looks fantastic. I bought the Audiovox PNP3. I installed it where the NAV usually is and it's angled towards the driver. It looks clean and factory like. The orange display matches the OEM radio and dash lights perfectly.
You need to use the search button. It's all here already. But I'll post it again:
Have you tried finding finding a stereo patch cord with 1/8" right angle mini-plugs for your Roady or MP3 player? They look much cleaner as they don't stick out as far. I looked everywhere and finally found them here:
For those with the low volume aux situation, you can purchase a 1/8 volume amplifier which boosts up your sound keeping the same quality. It was 20 dollars at radio shack and works great.
04 Titan LE CC 4x4 - Smoked n Loaded
What is the '1/8' ?
Put in
volume amplifier
amplifier
at radioshack search online and didn't come up with anything that seemed applicable.
Part number or additional info would be very helpful.
Thanks!
Yes, please tell us exactly what the name and part number is. I bought a right angle gold plated adapter that was about 6 inches long with a volume control on it. Even turned all the way up it was way too low even with the radio volume on 31. I also had the volume level at full on the PNP3 unit.
for this problem I used the plans by Sammy Sandbag under the thread of 'hardwire MP3 player'. Works great, is damn near exact volume of CD. To eliminate the hissing noise sound across the wires, just run the power cable to the breaker box by the glove compartment and add an inline ground loop isolater ( not powerd, 10 bucks at radio shack ). Clean out of site look.
P.S. If you are willing to drill a little bit, you could poke a small hole under the rubber stopper where the nav unit would go and have your AUX in port run to that hole rather than down in front of the Head Unit and in the way, and you would still have an input for MP3 players and such without having to unhook your SAT radio. Just move the input Sammy Sandbag put to the side up on top. All this stuff only took me 1 hour to install so it woudnt be hard. Let me know if you have any questions. Hope it helps
OK last thing i promise, when i ran it to the breaker box, i plugged into the 15 breaker attached to the Stock Subwoofer, you can read it on the back of the key that covers the circuits.
Forgive me for sounding really dumb. What all do I need? The PIE LD-1 is the main piece, but what actual wiring do I need and exactly how is it hooked up?
