Old 10-30-2004, 07:25 PM   #1 (permalink)
xm roady sound
does any one have sound problems with there roady hooked up through there aux port. i have the volume on the roady at its peak and i have to turn the radio all the way up to get good sound out of it.
firefighterffd is offline   Reply With Quote
Old 10-30-2004, 08:21 PM   #2 (permalink)
I am hooked up the AUX with my Roady 2 and have perfect sound, the volume on the Roady is set to high, but the volume on the stereo is inline with the CD/Radio etc.
cajunscotsman is offline   Reply With Quote
Old 10-30-2004, 08:44 PM   #3 (permalink)
what kind of hook up did you use.
Old 10-31-2004, 02:59 AM   #4 (permalink)
I just have one of those regular stereo jack to jack cables from radioshack..
Old 10-31-2004, 08:45 AM   #5 (permalink)
Pugsly's Avatar
need to put and in line pie thingy. the aux port lacks the power to clearly boost the signal. I'll find the thread that describes the install.
Hardwired MP3 Player
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
Pugsly is offline   Reply With Quote
Old 02-22-2005, 07:37 PM   #6 (permalink)
jrmkel's Avatar
Sorry to bring up an old thread but....
When I plug my Roady2 in thru the AUX input the left front and right rear speakers are the only ones to work....in other words no sound thru the passenger front speaker or the drivers rear speaker.
Am I doing something wrong? Anyone else have this problem?
thanks for any help guys.
04 SE CC 4x4 Copper
Tekstyle Profile cover
XM Roady2
jrmkel is offline   Reply With Quote
Old 02-22-2005, 07:42 PM   #7 (permalink)
Roady 2 sound
The Roady 2 has a volume control option that you set to a higher level.
John
johnszcz is offline   Reply With Quote
Old 02-22-2005, 07:47 PM   #8 (permalink)
jrmkel's Avatar
I know.. I have the volume all the way up on the Roady2 but I still have NO sound from the passenger front speaker or the driver side rear speaker.
04 SE CC 4x4 Copper
XM Roady2
Old 02-22-2005, 08:38 PM   #9 (permalink)
The cable you're using might not be a stereo cable, betcha that's it. Mono and the stereo cable almost look identicle to each other. I tried the cable in the Aux port, but even with the Roady2's volume all the way up it still wasn't as loud as I thought it should be. HTH's
John C.
TexasTitan04 is offline   Reply With Quote
Old 02-22-2005, 08:58 PM   #10 (permalink)
jrmkel's Avatar
Thank you! I'll bet you're right. Problem solved.
04 SE CC 4x4 Copper
XM Roady2
Old 02-23-2005, 02:28 PM   #11 (permalink)
Roady 2 audio output varies widely from channel to channel and what music is played.
Old 02-23-2005, 02:28 PM   #12 (permalink)
Have you adjusted your fader and balance controls?
