Old 11-03-2004, 07:07 AM   #1 (permalink)
Huey130's Avatar
Send a message via AIM to Huey130
What does the base stereo look like?
I know the dash panel I'm getting to replace the 6 disc changer is double din right? Is the base model a double din or does it have a cubby hole?
(o o)=(o o)=(o o)=(o o)=(o o)=(o o)=(o o)=(o o)
Craig "Huey" Stewart
Just some guy with a wrench
(who also used to have a funnier signature )
Huey130 is offline   Reply With Quote
Old 11-03-2004, 08:50 AM   #2 (permalink)
RS250R's Avatar
do not know about the stock equip on the XE, but I know METRA make a kit that even includes a pocket for the "extra" space... the part number was listed somewhere on the board just recently
05/04 Deepwater CC BT SE popular w/bench, added splash guards, step rails, hood protector, Myron & Davis factory like DVD & TV System
'00 Honda RS250R
'00 Aprilia RSV Mille
RS250R is offline   Reply With Quote
Old 11-03-2004, 09:03 AM   #3 (permalink)
WazzuCoug's Avatar
Send a message via MSN to WazzuCoug
The stock XE radio is a double din single cd.
WazzuCoug is offline   Reply With Quote
Old 11-03-2004, 09:05 AM   #4 (permalink)
The base model radio (standard in XE and SE with no options) is a double DIN form factor. Essentially it is the same radio that is equipped in the base Frontier.
Metra has a couple of mounting kits that will fit a single DIN radio into the double DIN opening and includes a 'pocket' that fills the unused space. The one I used was 9417 which requires some modification to work. There is a newer one specifically for the Titan, model number 99-7705, which also has a 'pocket'.
