Old 11-14-2004, 11:04 AM   #1 (permalink)
Subwoofer boxes
Anybody know where i can get sub enclosures for my king cab.Last step of audio install.That will fit under the rear seats. Looking for them to fire down.
Everything i have seen was couple hundred too much for me right now.
acontisr is offline   Reply With Quote
Old 11-15-2004, 06:20 AM   #2 (permalink)
Brian mc's Avatar
i put two kicker solo 8s under my seats in a crew cab i spent 100 on each box i didnt think it was that bad. what size are you trying to put in yours
Brian mc is offline   Reply With Quote
Old 11-15-2004, 07:43 AM   #3 (permalink)
QWIKWHIP's Avatar
How about this one? Sounds like just what your looking for.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 11-15-2004, 03:36 PM   #4 (permalink)
katsu's Avatar
I have a single 10w3 JL Audio under the rear driver side of a king cab,and everything work perfect. This one was custom made, you can have the specs if you want.
katsu is offline   Reply With Quote
Old 11-15-2004, 09:05 PM   #5 (permalink)
katsu,
I'm planning on using the same sub for my Crew Cab. Would you mind giving us the spec's? Thank You.
babylon is offline   Reply With Quote
Old 11-16-2004, 08:01 PM   #6 (permalink)
Kmu
Yes, please give us info on the box used for the JL, also the amp and how did you wire the amp...
THX
Kmu is offline   Reply With Quote
Old 01-06-2005, 09:32 PM   #7 (permalink)
Hey katsu, would you mind giving us the specs for your sub?? Thanks. Im planning to use a single sub that will be put under the rear driver side of the king cab.
chanman2344 is offline   Reply With Quote
Old 01-06-2005, 09:35 PM   #8 (permalink)
Titan4x4Aggie's Avatar
This should be as good / better than whatever they had in mind:
How To: Custom KC 10" Subwoofer Box ( '04 Nissan Titan King Cab )
Custom KC Rear-Seat Sub Box - Courtesy of Aggie Engineering
My new gas saver!!!!!!
Old 01-06-2005, 11:39 PM   #9 (permalink)
1BadTitan's Avatar
I went with a pair of 12" jL's (12w3v2's) under my rear seats. I built 2 seperate 12" boxes to fit under.
[color=Blue]1BadTitan
Old 01-07-2005, 11:06 AM   #10 (permalink)
Can you post pics of the box used, also info on them, what amp did you use also for those 12w3v2...
THX in advance.
Old 01-07-2005, 11:09 AM   #11 (permalink)
1BadTitan's Avatar
I'll post pics monday, I have alot of new stuff to show off. I'm pushing the JL's with a Phoenix Gold Ti600 (300x2 @ 4 ohms) They are DVC so I'll wire them in parallel and run the amp at 2 ohms.
Old 01-07-2005, 12:22 PM   #12 (permalink)
Jaimster's Avatar
Any JL Audio Sub specs are right here!
http://www.jlaudio.com/subwoofers/discontinued.html
Galaxy Crew Cab LE
Jaimster is offline   Reply With Quote
