Originally Posted by r_mojo1
Nice job... I am about to install my amp and sub very soon. The thing is, I want to keep my original CD player. I have the popular package with the 6 cd changer. Is it possible to install the amp to this CD player. Were do I connect the remote wire from the amp (to the ground???).
One last thing, how do I dismount the CD player from the dashboard? and were is a good place to drill the firewall to run the cable from the battery to the amp inside the truck. I see that you went across the engine, from the battery to the drivers side then inside the truck, why this way??
The central dash cover just pulls off. There are no screws. It is held by clips. After you pull it off, you have to disconnect the wire connectors on the back. The head unit is located behind the central dash cover, and is held in its bracket by four screws.
There are three locations that people have used to run the power cable through the firewall (w/o drilling):
1. There is a 1/2 hole with a rubber plug on the driver's side firewall, just above the hood latch release cable grommet. If you pull out the plug, you can make a hole in the plug, run your power cable through, and put the plug back in the hole to serve as a grommet so your power cable doesn't saw on the metal firewall.
2. Some people have run the power wire through the hood latch release cable grommet.
3. Some people have run the power cable through the A/C drain grommet on the passenger side firewall.
You are supposed to keep the power cable away from speaker & amp signal wires to avoid noise.
