Old 12-03-2004, 03:44 PM   #1 (permalink)
WazzuCoug's Avatar
Send a message via MSN to WazzuCoug
Front Seats
Anyone removed the front passenger/driver/middle bench seats in their titan? I am curious how many bolts/tools needed to accomplish such a task. Are there any special requirements other than the airbag/seat sensor disconnecting? How much time? Thanks!
WazzuCoug is offline   Reply With Quote
Old 12-03-2004, 03:49 PM   #2 (permalink)
smoketitan's Avatar
four screws per seat, go driver them passneger, and then the middle console
the middle seat/console has four main bolts,and two smaller bost for the plastic peice closests to the floor
takes about 1o minutes
14mm, and 12mm socket will be needed and a small flat screw driver to disconnect the seatblet/airbag sensor wire
make sure you dont turn on the ignition with the passenger seat not connected tothe airbag sensor or you will triggger the flashing airbag sesor ont he drivers console and it will a have to be reset
Old 12-03-2004, 04:37 PM   #3 (permalink)
WazzuCoug's Avatar
Can you do just the passenger seat or do you really have to do drivers first then passenger then middle?
Old 12-03-2004, 04:40 PM   #4 (permalink)
smoketitan's Avatar
they are all screwed to the floor individually, so you can do one side or the other individually
but if you are removing all the seats it is better to take the driver/passenger seats out first --then do the center seat/console
