Old 12-04-2004, 12:17 PM   #1 (permalink)
Soonerdude's Avatar
audio system advice
In building my system, I decided to cut a couple corners and now I'm having to go back and correct the errors.
1) Profile amps - not bad, but not real good either. Thinking about Kicker 600.1 and 650.4 or PG Xenon 600.1 and 100.4
2) RF P2 8" sub - need more bottom end. I am building another box to go under the read seats and house 2 10" subs(up facing), 2 midbase drivers (forward facing) and a monoblock amp (as long as the dimensions are less than 18.5" X 11.5 X 3.5. I am looking at Elemental Design 11KV2 and Polk Audio MM2104. Each sub will have 0.59 ft^3.
Need opinions or other ideas. The 4 channel sub will need to be 2ohm stable as I will be presenting that type of load from the rear speakers.
All ideas welcome. Still on a budget, but this time I will do it right.
2008 Titan LE CC 4X4
Green Performance Filter
Flowmaster 50 Series
Soonerdude is offline   Reply With Quote
Old 12-04-2004, 01:57 PM   #2 (permalink)
smoketitan's Avatar
my xenon overheated wouldnt recommend it
Old 12-04-2004, 02:04 PM   #3 (permalink)
The Memphis 1100 watt into 1 ohm is a powerhouse that can be bought for around $500. It has all the featurs you would want in a sub amp.
04 Titan SE, CC, Big Tow, Utility Bed, PRG 2.5"f/1.5"r,
Flush is offline   Reply With Quote
Old 12-04-2004, 02:11 PM   #4 (permalink)
Soonerdude's Avatar
Thanks for your input. What do you know about these subs?
Old 12-04-2004, 09:35 PM   #5 (permalink)
4---- 8 inch JLAUDIO SUBS SOUNDS REALLY GOOD. PERFECT AIRSPACE
audio-system-advice-titan-001.jpg  audio-system-advice-titan-003.jpg  audio-system-advice-titan-004.jpg
solidaxlenissan is offline   Reply With Quote
Old 12-04-2004, 09:38 PM   #6 (permalink)
Supporting Vendor (Gold)
That Memphis amp would serve your needs!! What sort of advice our you looking for?
Front Stage Amp: Mmats SQ2175
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 12-04-2004, 11:53 PM   #7 (permalink)
smoketitan's Avatar
id get the ed sub
Old 12-05-2004, 11:01 AM   #8 (permalink)
Soonerdude's Avatar
Originally Posted by smoketitan
id get the ed sub
Thanks Smoke. That's the way I'm leaning. Any input on the Nine.1 amp? Good, bad, ugly?
Old 12-05-2004, 11:05 AM   #9 (permalink)
Soonerdude's Avatar
I've heard good things about the memphis amps. Thanks King. The advice I'm looking for is just opinions and options. I want to know how your experience with these products has gone. My bottom line is I don't want to have to go back and replace components of my system again. Doing it this once is bad enough.
Old 12-05-2004, 03:28 PM   #10 (permalink)
I feel you on that!! That's why I decided to go with Eclipse subs and Diamond full range speakers. I also went with Eclipse amps and the best DVD deck out there. I hate to 2nd guess myself so I decided to spend the extra money.. I'm really interested in SQ not SPL.
a select few."
Old 12-09-2004, 08:27 PM   #11 (permalink)
Brian mc's Avatar
I just left my mids and highs stock and put 2 kicker solo 8s in mine 800 what sony amp running in 2 ohm it sounds nice
Brian mc is offline   Reply With Quote
Old 12-10-2004, 06:51 AM   #12 (permalink)
Kicker is notorious for under-rating their amps. That 600.1 will propably be more like 900 watts X 1 ch @ 2 Ohm. Just an FYI.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Tech Tubes step rails, Truxedo Lo-Profile, K&N CAI, Flowmaster catback exhaust
MB Motoring Express 20"X9", Nitto Terra Grapplers 305/50 - 20
Sylvania Silverstar hi & lows, OEM fog lights, Blacked out OEM Grill
Armada front air dam, 2* timing advance
meckman is offline   Reply With Quote
Old 12-12-2004, 11:07 PM   #13 (permalink)
Soonerdude's Avatar
Thanks for the input. I've got two 11KV2's and a Nine.4 amp comming. eD rated this amp 50X4 @10.5 V. Thier technician told me it will be 75X4 @14.4V...should fit my needs for powering the main speakers.
Still undecided now between Kicker and eD Nine.1. I was really wanting something with topside controls (for ease of access). But the Nine.1 looks so good, I may sacrifice that.
