Question About Drilling Through Firewall
I know this has been covered in detail, and I've read all of the posts. I am planning to drill through the passenger side and use a grommet for 0 gauge. I remember seeing the picture of the N on the rubber underneath the carpet, but I looked today and there's no N??? Doesn't really matter though, because I can tell where the location is, just right of the A/C return (at least I think that's what it is). Anyway, my question is this: What's the best way to access the hole from the engine side? Did you guys have to remove something in the engine that gave you more clearance to the hole? Also, were you guys able to remove that rubber foam or just peel it up? I didn't see a way to remove it.
