the subs are mounted in a glass enclosure under rear seats, currently i have one amp in the bottom of the passenger rear seat, but i am clueless with the other amp, exact same size
I see know. Yeah you could mount the amps on the rear wall. My biggest amp measures 21inches in length (Eclipse DA7232) and I have it under the drivers seat. I have my Eclipse 5422 under the passenger seat. My subs are under the rear split bench seat just like yours. You should be able to mount that amp on the rear wall real easy.. If you search the forums you will see others who have done it. What kind brand of amps and subs you running? Got pictures?
__________________ 2007 Toyota Tundra DC SR5 TRD 4X4
Front Stage Amp: Mmats SQ2175
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
i have 4 l5's kicker 10" and the tewo xeon phoenix amps 1200:1 and 400:2. I glassed them in with .75 cu^3ft air per sub. had just enough space
wait you glassed 0.75 cu ft per side?? Id love to see that??? I am having abox made that is 0.89 per side firing forward, so I guess its possible., but yours fire up I assume right??
so do the new 05 l5's sound better than last years model ???
oh yeah my two (soon to be three) amps are mounted on a board that I screwed into the cab wall using the stock hex bolts and a few steel back straps --very tight fit due to the width of my amps
