Old 12-26-2004, 01:45 PM   #1 (permalink)
Boone-Titan's Avatar
Question for the Sparkies (Electrical Tech)
I am about to begin adding some back-up lights and driving lights and would appreciate it if someone with an electrical background could answer the following. In the attached schematic, I have the relays being energized (closed) thru the on/off switch (switch hot). Is this the best way? Would it be better to switch the ground side instead (relay hot)?
Thanks in advance
Boone-Titan
Radiant Silver LE, CC, 4WD, Big Tow,
DVD, Side Air Bags, LowProTruxedo,
Bed Extender, Vent Shades, Lund Bug Shield,
Bed Tube Rails, Street Scene Grills, KC Slimlites,
Auto Tailgate Lock, Aux Back Up Lights
Boone-Titan is offline   Reply With Quote
Old 12-26-2004, 05:08 PM   #2 (permalink)
frankyD's Avatar
looks good to me. You look like you know what your doing.
frankyD is offline   Reply With Quote
Old 12-29-2004, 08:39 PM   #3 (permalink)
titanwild's Avatar
Boone,
What you've shown will work fine, but there are some advantages to switching the ground side of the relay coil. That provides some options (Solid state switching, for example) that are more difficult if switching the hot side.
Good Luck!
TitanWild
DeepWater 4x2 KingCab SE,
Big Tow, RF Pop, and Bed Packages, 29Mar04 MDate, Custom Flo-Pro Crossflow Dual Exhaust,
JetTech Traction bars, K&N drop In, OEM Fogs, XD5 9005/9006 Xenon bulbs, Viper 350 Alarm.
titanwild is offline   Reply With Quote
Old 01-02-2005, 07:20 PM   #4 (permalink)
Austin's Avatar
Use pull-to-ground instead of switching the hot side.
MY04 SE King Cab 4X4 SOLD!
Old 01-02-2005, 08:23 PM   #5 (permalink)
garo1's Avatar
I'd switch the ground and it'll keep it consistent with the truck wiring or at least from what I've seen on a few of the schematics.
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
