Old 01-04-2005, 07:35 PM   #1 (permalink)
Amp Power Wire?
Does anybody have a suggestion on a good spot to run the amp power wire through the Firewall?
johnlarance is offline   Reply With Quote
Old 01-04-2005, 07:41 PM   #2 (permalink)
Supporting Vendor (Gold)
left side next to the hood latch cable there is a 1/2" hole with a rubber grommet that you can remove..
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 01-04-2005, 07:59 PM   #3 (permalink)
Thanks
Thanks for the info.
Old 01-04-2005, 08:01 PM   #4 (permalink)
No problem!! If you need anything else SmokeTitan, Bestatchess or myself should be able to help out..
a select few."
Old 01-04-2005, 08:11 PM   #5 (permalink)
Hi Lizardking,
Is there a spot that you are aware of along the firewall on the same side as the battery?
Old 01-04-2005, 08:15 PM   #6 (permalink)
Not sure I have never looked over there. I ran all my power wires down the left side. You might try to search (forum) but I think with the HVAC being there I don't think you will have any luck. You could drill your own hole but be very careful.. What size power wire do you plan to run 1/0 or 4gauge?
a select few."
Old 01-05-2005, 12:44 AM   #7 (permalink)
smoketitan's Avatar
I drilled on the passenger side--used a 1" unibit and a 18v drill ( 1/2 shank is needed)
but I have 1/0 ga wire though
4ga you only need a 1/2" drill bit
Old 01-05-2005, 09:50 AM   #8 (permalink)
DLHTITAN's Avatar
Passenger side on the "N" as mentioned by others in here. The "N" is on the rubber/foam padding. Just drill on the upper portion on the "N" and make sure you clear the ac line on the other side. I would recommend a pilot hole first for centering it and checking for clearnace.
2004 Nissan Titan SE KC 4x4
Mods
Interior: Husky Floor Liners, Wet Okele Seat Covers (Front and Back)
Exterior: Pro Tech Headache Rack, Custom built UWS Toolbox (Dented upon shipment), 15% Tint
I.C.E. Clifford RSX Matrix 3.5 Responder 2-way Remote Start and Alarm, Kenwood DDX-7015, Kenwood KHDC710 Music Keg, JL Audio 4/300 amp, JL Audio 500/1 amp, MB Quart PCE216 6.5" components, MB Quart PCE269 6 x 9" Components, Jl Audio 10w6v2, Pac- Swix, Acelevision Flush Mount Camera, New ground wiring w/ battery terminals and D block
Suspension: 6" Fabtech Lift Kit
Wheels and Tires: 18 x 8.5 Enkei RT6 (Black Centers), 35/12.5/18 Toyo Open Country M/T
On Order: Gisbon Split Rear Dual Exhaust, PIAA 510 Driving Lights, PIAA 2100 Fog Lights
My Company: Click Below
www.dlhinc.com
DLHTITAN is offline   Reply With Quote
