Old 01-05-2005, 12:29 AM   #1 (permalink)
6 3/4 speakers
Is there anyway I might be able to fit the Alpine SPR-176A component in the front and back doors of my 04 Titan SE crew cab or maybe the Infinity Kappa 60.5cs component? Crutchfield gives me the option of putting the Infinity in the front door, but when I scroll down on the speaker info it says the speakers will not fit.
If both of these two speakers won't work then I was thinking of putting the 5 1/4 Alpine components in or maybe even the Polk db 6 1/2 because they have the buy one get on half off thing.
I don't want to run any amps, except for my subs because I use an Alpine HU with 26 RMS, so I want speakers that will work fine with lower RMS ratings.
BenKRiley is offline   Reply With Quote
Old 01-05-2005, 12:34 AM   #2 (permalink)
smoketitan's Avatar
i had the 177r set, which Id recommend over that set, but anyway you have to make a baffle out of mdf or other wood to attach it to the door thats all
really simple takes 10-15 minutes
