Old 01-05-2005, 10:14 PM   #1 (permalink)
aftermarket thoughts and questions
I really like the Alpine R Components, but I am not sure I want to have to make a MDF baffel or ring so I was thinking of just getting the 5 1/4 from crutchfield. Is there any reason why I should not do this and just build the required baffels and rings so that I could install the 6 3/4 Alpine components?
I am going to install a 26 RMS alpine HU to run the speakers in the doors. And I have an amp and two 10 inch subs to cover the bass. I just figured the 5 1/4 would provide good midrange sound.
One thought I am having is that I might find it hard to mount the four crossovers for the front and rear door components. Any suggestions?
BenKRiley is offline   Reply With Quote
Old 01-05-2005, 10:21 PM   #2 (permalink)
Supporting Vendor (Gold)
I wouldn't go with anything smaller the 6.5 midrange speakers for better mid range bass balance not mention better power handling. You can secure the crossovers inside the doors or do what I did and install them under the dash (Kingcab) one on each side for ease of access... I have db adjustments on mine I might play with when I get sometime.. If you have a crew cab or just want to do components all the way around I would mount them in the door with 3M industrial Velcro they will never fall.. I would also consider dynamating your doors since you will be in there anyway.. If your going to do a install take your time and do it right.
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 01-05-2005, 10:30 PM   #3 (permalink)
Velcro?
That is great advice. I will try the velcro out.
So it sounds like I will just have to create the baffels and rings.
Thanks for the help.
Old 01-05-2005, 10:36 PM   #4 (permalink)
hurricanefan1's Avatar
I agree with LizardKing. I am starting on my doors now, and going with the Audiobahn ACIS62's for all 4 doors. If you plan to put a little more thunder in the doors, definately dynomat them, you will get a cleaner sound.
hurricanefan1 is offline   Reply With Quote
Old 01-05-2005, 10:45 PM   #5 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Go big, take your time and do it right...as suggested above!
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 01-06-2005, 11:26 AM   #6 (permalink)
WazzuCoug's Avatar
Send a message via MSN to WazzuCoug
Lizard,
Where did you mount your crossover on the passenger side? I cant seem to find a good place for mine. Where are everyone elses?
*T-REX billet grill
*Diamond Hex components
*Alpine 7941 HU
*RF 800a2 800a4
*RF power HX2 15"
*Viper 791 autostart
*Flowmaster 40 exhaust
*Volant air intake
*Tint
*Bug shield
*Removed decals
*Stillen rollpan
WazzuCoug is offline   Reply With Quote
Old 01-06-2005, 11:40 AM   #7 (permalink)
Originally Posted by WazzuCoug
Lizard,
I'm in the middle of installing 2 sets of MB Quart RCE216 components. I mounted my crossovers to the inside surface of the door panels, in the hollow area near the arm rest. I used 3M hoop and loop (velcro).
DesertTitan is offline   Reply With Quote
Old 01-06-2005, 11:57 AM   #8 (permalink)
dman's Avatar
Lizard's advise is very sound (pun intended). 6 1/2's are much better than 5 1/4s especially for the low mounting position in the doors.
dman is offline   Reply With Quote
Old 01-06-2005, 04:46 PM   #9 (permalink)
Thanks for the advice
I took the advice given and "went big." I got the 6.5 type R component speakers for both the back and front doors. I also decided to go ahead and get a 40x4 amp to run them instead of letting the HU do it.
Now all I need to figure out is how to mount two amps and four crossovers behind the seat and how to build the baffels for the speakers. I am going to search the forum archives, but I might be back later with another post asking for help.
Thanks again everyone.
Old 01-06-2005, 05:17 PM   #10 (permalink)
SarkaZm's Avatar
Sweet, you should be happy with that set up. What kind of amp did you get?
More Pic's Here
Old 01-06-2005, 05:20 PM   #11 (permalink)
SarkaZm's Avatar
Speaking of MB Quart, has anyone heared these REC269 They should provide a little more bass and drop right in (with RF stereo). Any thoughts?
More Pic's Here
Old 01-06-2005, 07:19 PM   #12 (permalink)
on order
In all of my past systems I have always been very happy with my alpine head units. I have tried pioneer and sony, but have always found my alpine a step above all the others. So just for the fun of it I figured I would go all alpine for this install. So this is what I have on order from crutchfield.
CDA-9835 HU
MRP-F240 AMP 40WX4
SPR-176A 6.5 component speakers for both the front and back doors
I plan to also get the MRP-350 and either a pair of 10 inch type R subs or a pair of 12 inch type R subs. I am not sure which ones. I haven't had a chance to hear them yet. I usually like the tens because they are more responsive and I rarely listen to anything other than bands like The Mars Volta, Tool, or some other rock music.
Right now I am just going to use my MRP-200 amp with my tens that I bought something like 8 yrs ago. I don't even remember what brand they are. It was something like Cardiac I think. But they have lasted this long and still sound great.
Old 01-06-2005, 08:35 PM   #13 (permalink)
Here is a question for you...Do the speakers you are getting fit in without having to cut the ring in the door to get them mounted. I am having to cut my ring to get my Audiobahn ACIS62's to fit correctly in the door, and build up a mounting ring. You may want to check that out, I knew what I was in for when I got mine, so it was no big deal to me.
Old 01-06-2005, 09:16 PM   #14 (permalink)
I know I am going to have to use MDF to build a ring for the back doors and baffels for the front doors. I have kind of done this before on a past install so I am not to concerned. I was kind of hoping I would not have to cut the openning wider, but I can if I have to.
How is your fabricating going? Any tips?
Old 01-06-2005, 09:21 PM   #15 (permalink)
I didn't have to make the opening wider. I basically cut the inside ring down to about 3/4" to leave something to put the mount on, right now, I am playing with ring sizes to get the best fit. I will let you know how things go, and get pics of it. The Navy thing kind of slows things down LOL.
