Old 01-09-2005, 02:00 PM   #1 (permalink)
Overhead console connnetors
Anyone know what the 2 connectors behind the first storage compartment are? One is 2 wire and the other is 4 or 5. Is this where homelink plugs in? If so is it documented somewhere what these wires are? I would love it if it was a 12v source.
falchulk is offline   Reply With Quote
Old 01-09-2005, 03:44 PM   #2 (permalink)
garo1's Avatar
Yeah, if we're talkin' about the same connector. They are for the mirror and its 12 VDC.
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 01-10-2005, 07:34 AM   #3 (permalink)
schneid's Avatar
Okay, how 'bout
the white connector in the bracket under the dash to the right of the steering wheel?
schneid is offline   Reply With Quote
Old 01-12-2005, 10:53 AM   #4 (permalink)
loufish's Avatar
NBUS for sat radio?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 01-12-2005, 11:07 AM   #5 (permalink)
scr38's Avatar
That is the OBDII connector. Thats where you connect the device (ConsoleII) to read error codes, reset, program, etc.
