Old 01-09-2005, 11:57 PM   #1 (permalink)
JIKSER's Avatar
Sub box question re: PolyFill
I plan on making my own subbox for the CC using (2) 10's and a buddy of my mine has mentioned putting PolyFill inside the enclosure. What are the benefits of having Polyfill in a sub box? How much PolyFill should I use assuming the enclosure's volume is 0.7-0.9 cu/ft?
TIA
Wil
04 CC SE BT/UB
22" Panther 384c shod with Nitto 305/45/22 CLICKY
Custom TV's and PS2 system CLICKY
Banks Monster Exhaust (Modified side exit) CLICKY
and a 02 RC51 trackbike CLICKY....CLICKY2
JIKSER is offline   Reply With Quote
Old 01-10-2005, 12:18 AM   #2 (permalink)
1BadTitan's Avatar
figure 1 pound of polyfill to every 1-1.5 cubic ft.
[color=Blue]1BadTitan
Old 01-10-2005, 06:49 AM   #3 (permalink)
Titan4x4Aggie's Avatar
if your box is built to the proper volume for the sub, you shouldn't need polyfill. i think that's only used when the box is undersized and you want it to "trick" the sub into thinking is in a larger box.
a box that's too small for the sub will result in lower bass frequencies but less of a range, and a larger box than the sub requires will lose the low freq and pick up higher frequencies.
My new gas saver!!!!!!
Old 01-10-2005, 08:01 AM   #4 (permalink)
Supporting Vendor (Gold)
Exactly what Titan4x4aggie says!
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 01-10-2005, 08:27 AM   #5 (permalink)
The tech at www.edesignaudio.com told me that it was better to just make the box the right size w/o any polyfill. If you make a small box and use alot of polyfill to compensate, it can create overheating problems for your sub driver.
Old 01-10-2005, 08:59 AM   #6 (permalink)
You should never need polyfill unless the box was poorly designed or you switch to different subs that require a bigger box and you don't have the space to build another box.. I don't use polyfill nor would I ever use it.
a select few."
Old 01-10-2005, 09:18 AM   #7 (permalink)
1BadTitan's Avatar
Me either but if your like me, I built two boxes 1.2cuft per box for a pair of jl12w3v2's. The space under the rear seats is just too tight for anything larger. The specs say 1.25-1.5 cuft. I want to use the 1.5. So I'll use 1/4-1/2 lb of polyfill to get the 1.5cuft and there will still be plenty of room for heat disapation.
Old 01-10-2005, 11:18 AM   #8 (permalink)
JIKSER's Avatar
Making this box may take me a few days since 12 hr shifts dont give me enuff free time. I will take exact volume measurements and see what subs i need to use. Id rather opt not using polyfill due to heat. Thanks for the replies fellas
Wil
04 CC SE BT/UB
Old 01-10-2005, 11:40 AM   #9 (permalink)
How did you get 1.2 cuft per side? The only way I can come up with over 2 cuft will be with a single(both side) enclosure that will require removing the jack and protruding into the back of the seat area. Also will use fiberglass to get as much space as possible? Is there something I missed? Did you raise your rear seats?
04 Titan SE, CC, Big Tow, Utility Bed, PRG 2.5"f/1.5"r,
Flush is offline   Reply With Quote
Old 01-10-2005, 11:44 AM   #10 (permalink)
What subs you guys running to need that much cuft? Are you running ported boxes or something?
a select few."
Old 01-10-2005, 12:08 PM   #11 (permalink)
Yes, I am going with two ported 10"s. 1 cuft ea.
Old 01-10-2005, 12:43 PM   #12 (permalink)
That explains the need for bigger boxes!! Have you guys considered sealed its the way to go for SQ. Sealed boxes do however require more power to operate the subwoofer.
a select few."
