Old 01-12-2005, 04:10 PM   #1 (permalink)
scsTiTan's Avatar
SWIX IR mounting
Anybody with the SWIX - where did you mount your IR sending light? I have tried two locations so far (Thats two holes in my center console) and didn't have any luck with the first (Mounted in the small plug right above the shifter) the second I have is right between the shifter and cup holders, but it needs to be sitting higher than flush to work, so now I'm looking for ideas. Anybody?
Steve
09 CC LE 4x4
MODS: DR Front CO w/ PRG UCA's and spacer, Radflow Rear shocks
Kenwood DNX 8120
SOLD
04 KC LE 4x4(BT/OR)
Super Fast Silver
scsTiTan is offline   Reply With Quote
Old 01-12-2005, 04:19 PM   #2 (permalink)
smoketitan's Avatar
mounted mine right on the metra dash kit, driled a hole on the top right hand corner
rran the small little grommet through and then slid the ir transmitter though
it gets washed outif there is heavy sunlight
so if had it to do again I would mount it on the bottom left hand corner to sheidl it from sunlight more
make sense??
it needs to as close to the deck sensor as possible
whats happening with yours are you programmed it right? is it in mode three??
Old 01-12-2005, 07:53 PM   #3 (permalink)
scsTiTan's Avatar
Yea mine works fine, got it programmed no problem. The only problem I'm having is finding a good place to mount without drilling anymore holes
I was thinking about the front of the center storage console right below the lid, but not sure if drinks, coffee cup etc would get in the way.
Do you have pics of your install?
Steve
Steve
09 CC LE 4x4
Kenwood DNX 8120
SOLD
04 KC LE 4x4(BT/OR)
Super Fast Silver
Old 01-12-2005, 08:28 PM   #4 (permalink)
Hey all,
Quick question....where are the wires for the steering wheel control. Where did you guys get the wire placements from?
Tileteam
tileteam is offline   Reply With Quote
Old 01-12-2005, 08:34 PM   #5 (permalink)
scsTiTan's Avatar
I'm not sure I understand the question.
I think what your asking is which wires do you tap into for the controller to hook-up too - if that is the question then they are located behind the factory receiver. The wire harness that you tap into is the one that looks like a computer cable plugged into the side of the factory radio (Depending on which radio you have) I'm not positive about the colors right now but a quick search will yield the answer.
If you need more help I will be glad to help as much as I can, and there are others here that I'm sure will chime in.
Steve
Steve
09 CC LE 4x4
Kenwood DNX 8120
SOLD
04 KC LE 4x4(BT/OR)
Super Fast Silver
Old 01-15-2005, 06:45 AM   #6 (permalink)
Soonerdude's Avatar
I've got mine mounted between the cup holder and the shifter (at gears 1&2). Seems to work well. Cups and that sort do not seem to affect it at all.
2008 Titan LE CC 4X4
Green Performance Filter
Flowmaster 50 Series
Aries Bull Bar
Diamond Audio / Polk Audio
AudioControl DQL-8
Optima Yellow-Top
Soonerdude is offline   Reply With Quote
Old 01-15-2005, 11:09 AM   #7 (permalink)
I did a search for swix on gogle and it came up with a bunch of ski products. Anyone know what the whole name is?
Smoke 2005 Nissan Titan SE CrewCab 4x4
Off road package, tow package, RF package
Magnaflow exhaust, ventvisors, bug guard, Leer hard cover
scubakleev is offline   Reply With Quote
Old 01-15-2005, 11:11 AM   #8 (permalink)
Never mind I got it, PAC SWI-X
