Old 01-17-2005, 05:17 PM   #1 (permalink)
scosche install kit
is anyone using the scosche nn1451b kit, rather than ordering an oem titan bezel and the metra kit? the price seems way too good; anyone familiar with the fit and finish?
http://www.crutchfield.com/S-1Wtj7ab...1&I=142NN1451B
edscholl is offline   Reply With Quote
Old 01-17-2005, 05:23 PM   #2 (permalink)
Is the position of the flasher switch and the airbag light reversed? If so, won't that cause problems?
Old 01-17-2005, 06:25 PM   #3 (permalink)
Supporting Vendor (Gold)
Yep everything is reversed and it has the aux plug too....Looks like arse!!
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 01-17-2005, 06:52 PM   #4 (permalink)
hurricanefan1's Avatar
I have that kit, and I needed those aux holes to be there as I will be using them for a different function. The hazard light and airbag light was a quick fix, just switch them around when you take the bezel off. I will post more pics soon as I finish my project. Damn Navy job keeps getting in the way
hurricanefan1 is offline   Reply With Quote
Old 01-17-2005, 07:45 PM   #5 (permalink)
goathead's Avatar
is it just me, or does your fan knob not have numbers (0-4) like mine. weird. anyone else care to comment on this?
steve
steve
Old 01-17-2005, 07:48 PM   #6 (permalink)
I wonder if he has a 2005?
a select few."
Old 01-17-2005, 10:22 PM   #7 (permalink)
Yep, I got the 05.
Old 01-18-2005, 11:52 AM   #8 (permalink)
i have an 04 and no numbers...
Old 01-18-2005, 03:34 PM   #9 (permalink)
smoketitan's Avatar
weird my 04 has the numbers also
how does that scoshe match in color??
I want the scosch black radio mount as it seems to fit better than the metra kit, I may have to pick that up though
care to comment of the radio mount fit??
may I ask with that line driver can you still change the volume with the deck??
Old 01-18-2005, 07:26 PM   #10 (permalink)
The color matched perfect, and the mount fit is dead on. I have the option to change the volume with my deck or the pre-amp. I set the pre-amp volume where I want it, and then use my deck volume, that way, I can hit the attenuate button on the deck to turn down the sound instantly when I get close to cops, or in a neighborhood.
Old 01-20-2005, 04:37 PM   #11 (permalink)
BLWedge09's Avatar
I've got an 04 and my fan knob has numbers. My Titan had the Double din opening bezel from the factory. Where can I find just the Metra kit online or locally? One thing I can say for the Scosche kit is that I actually like finish of the punch-outs (or whatever you want to call them) for the two extra knobs that the Armadas have better than the Nissan one. On the Nissan bezel these look unfinished and cheap in my opinion. But that's about my only complaint about the whole truck so looking at the bigger picture....really isn't a problem.
BLWedge09 is offline   Reply With Quote
Old 01-20-2005, 04:45 PM   #12 (permalink)
smoketitan's Avatar
do a search for metra there is a store link for it
I for one dont think it fits so well, lizard thinks otherwise. I like the fit of the scoshe radio mount better (at least for my alpine 9835)
but i will say its better to order the factory face plate over the scosche
Old 01-20-2005, 11:55 PM   #13 (permalink)
Yep I use the Metra single din kit with my Nissan double din faceplate... My Metra kit fits flush and looks fine!!
a select few."
