Old 01-25-2005, 12:07 PM   #1 (permalink)
Need Help!!!
where can i find a wiring harness to install an aftermarket cd player? no audio shop in alaska can even find one.
04 TITAN CC 4x4, 2/4 DROP, 20" DUBS, DEBADGED ALL THE WAY AROUND, STILLEN ROLL PAN, CUSTOM SHAVED TAILGATE, ARMADA PAINTED FRONT AIR DAM, PAINTED MIRRORS, HANDLES, AND WIPER COWL, BRUSHED BILLITT GRILL, CUSTOM 2.5" DUAL EXHAUST, NISMO R-TUNE INTAKE, STILLEN FRONT 14" BIG BRAKES AND MASTER CYLINDER BRACE, TINTED WINDOWS, BLACKOUTS, WINDOW VENTS, LCD, XBOX, CD/MP3 PLAYER, ALPINE TYPE "R" 12 W/500 ALPINE AMP, COMPUSTAR AUTOSTART/ALARM.
life_is_good is offline   Reply With Quote
Old 01-25-2005, 12:23 PM   #2 (permalink)
What radio do you have in the Titan and what CD player do you want to install?
If you have an AUX jack, you could connect an aftermarket CD player to input to the AUX input of the radio.
With no AUX input, you might be able to use an RF modulator to play the aftermarket CD player through the radio.
I don't think any of the Titan radios are setup to control or connect to an aftermarket CD changer.
Old 01-25-2005, 12:31 PM   #3 (permalink)
I'm Have An Eclipse Cd3434, And I Don't Have The Fozgate System In My Truck Just The Stock 6 Cd Changer And It Does Have The Aux Input, Isn't There A Vehicle Specific Wiring Harness To Install A Cd Player?
Old 01-25-2005, 12:41 PM   #4 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
Yes. Ordering from like www.crutchfield.com or snagging one off of www.ebay.com are 2 places typically to find one. They make a bezel for the Pathfinder that works in our Titans to reduce the opening from 2 dins to like 1 or 1 1/2 dins, too. Good luck!
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 01-25-2005, 12:46 PM   #5 (permalink)
I Allready Have The Install Kit. As Far As The Wiring Harness Goes, Crutchfield Has One That Says 95-up Nissan Trucks But Nothing Specificly For The Titan. I Could Order That One But I Want To Be 100% Sure Before Ordereing. I Guess I Can Just Call. Thanks For All The Help.
Old 01-25-2005, 01:07 PM   #6 (permalink)
Ahhh, you are replacing the OEM head unit (not just adding a CD player). Now I get it. Yes the 1995 & up at crutchfield will work. Also you can get a scosche nn03B from www.sjgreatdeals.com which I think is essentially the same thing.
I assume you already have the appropriate dash cover like this:
http://www.courtesyparts.com/Merchan...de=68260-A60CC
Old 01-25-2005, 01:14 PM   #7 (permalink)
That wire harness is almost a waste of money if you are adding amps and planning to use RCA pre-outs. I only used 2 wires from the original factory harness, the 12v lead and the 12v acc lead. I guess if you are using the factory speakers and/or the factory speaker wires then it is worth it. Otherwise you could just splice into the 2 wires listed above.
DesertTitan is offline   Reply With Quote
Old 01-25-2005, 01:41 PM   #8 (permalink)
Thanks For All The Help Guys, If The 95-up Harness Will Work My Local Audio Shop Has One. Thanks Again For All The Help.
