Old 01-28-2005, 08:45 PM   #1 (permalink)
XM Radio
My Titan didnt come with XM but It had DVD? What do I need to add XM in? Should i have the dealer do this or can any shop do it? Is my stereo even XM compatible? I dont have the 'SAT' Button on my dash.
HokieTitan is offline   Reply With Quote
Old 01-28-2005, 09:32 PM   #2 (permalink)
smoke_armada's Avatar
Do a search
top of the page........use the search function..........thread after thread after thread after thread answers this.
No harm, just search.
2004 Nissan Pathfinder Armada SE 2WD
smoke_armada is offline   Reply With Quote
Old 01-29-2005, 04:26 AM   #3 (permalink)
The Rockford Fosgate system and I believe also the midline w/ 6CD are pre-wired for XM. This means that there is already a cable w/connector under the driver side dash to plug the Nissan XM receiver into. You need the receiver, a micro magnetic roof mount XM antenna, and perhaps a splitter. The XM receiver used to accept the old style two wire XM antennas, so you needed to use a splitter to work for the modern single wire antennas. Many people put the antenna on the roof through the third brake light. Some people simply place the antenna on the dash.
Here is one place to buy the receiver:
http://www.nissanparts247.com/en_US/
Here is a splitter:
http://www.xm-radio-satellite.com/in...ROD&ProdID=277
Here is a magnetic roof mount antenna:
http://www.xm-radio-satellite.com/in...ROD&ProdID=242
If you have the center console shift (and not the column shift) this is the easiest way to install the XM receiver:
Photos of simple XM install
You should be able to install the receiver and antenna by yourself in about an hour. After installation of the Nissan XM receiver, you can use the RADIO button on the dash or the steering wheel controls to select the XM receiver as the music source (you don't need to have a SAT button). If you don't have the receiver installed, you obviously can't select the XM receiver with the RADIO button.
If you prefer to do things the hard way, here are Nissan's XM receiver install instructions:
http://secure.grubbs.com/sat_install/Titan.pdf
To install a roof mount antenna, you remove the two plugs in the rear portion of the headliner and use a deep well socket to remove the nuts on the third brake light mounting bolts. I think this socket is 7 or 8 mm. Then you put the magnetic mount antenna on the roof and run the wire through the hole into the cab, under the headliner, over to the rear corner of the cab, down to the floor, forward to under the driver's side dash along the side edge of the floor. I used one popsicle stick to slightly lift the edges of the plastic trim panel while using another popsicle stick to poke the wire under the trim panel. This allows you to tuck the wire safely away, out of sight, w/o removing any plastic trim panels.
You can also use after market XM receivers (Roady, Delphi, Commander) but they will not integrate with OEM N-BUS satellite connector and thus not be controlled by the factory controls. I think wiring through the AUX jack is the best way to connect these, but some people use RF modulators. If you search, you can find where people have mounted these nicely on the dash, and also nicely in the overhead sunglass holder.
Old 01-29-2005, 06:14 AM   #4 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
Something you might look into also, if you don't want to install the Nissan XM kit, is buy an aftermarket XM radio. I have a Roady 2 ($149 @ Crutchfield) that suits me great, comes with a mount and the magnetic roof antenna. Now I personally only connect up through the AUX port, but it sounds good and its easy to just unhook if I don't want the wires seen. Only thing that stays out is the mount, which I have attached to the dash, where on 4x4 models the offroad switch is located. On my 4x2 its only another blank spot on the dash LOL
Good luck
socket is 8mm
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
TomTom One 125 GPS
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 01-29-2005, 11:57 AM   #5 (permalink)
Wow
Thanks for all your help guys. Thats exactly what I needed to know.
Old 02-01-2005, 05:21 AM   #6 (permalink)
xm factory tuner
i have a nissan factory xm tuner,antenna,and n-buss fatory wiring kit with 1 year free xm service,everything is new in the box $325+shipping this is what i paid for it from another member,need the money something has come up/kobzjv/pkcrash2000@yahoo.com
kobzjv is offline   Reply With Quote
