Finished mounting the amps, crossovers and distribution block on the back wall. Kenwood Music Keg is under the passenger seat on a custom plate to get it off the floor. See if you can guess where I put the JL 10w6v2?
__________________ 2004 Nissan Titan SE KC 4x4
Mods Interior: Husky Floor Liners, Wet Okele Seat Covers (Front and Back) Exterior: Pro Tech Headache Rack, Custom built UWS Toolbox (Dented upon shipment), 15% Tint I.C.E. Clifford RSX Matrix 3.5 Responder 2-way Remote Start and Alarm, Kenwood DDX-7015, Kenwood KHDC710 Music Keg, JL Audio 4/300 amp, JL Audio 500/1 amp, MB Quart PCE216 6.5" components, MB Quart PCE269 6 x 9" Components, Jl Audio 10w6v2, Pac- Swix, Acelevision Flush Mount Camera, New ground wiring w/ battery terminals and D block Suspension: 6" Fabtech Lift Kit Wheels and Tires: 18 x 8.5 Enkei RT6 (Black Centers), 35/12.5/18 Toyo Open Country M/T On Order: Gisbon Split Rear Dual Exhaust, PIAA 510 Driving Lights, PIAA 2100 Fog Lights
looks awesome man! that is a great idea what you done with the sub. now the real question is, how?? lol also, have you installed any sound deadening? i would think that W6 rattles eevrything!
Finally Arrived:
2004 Nissan Titan 4x4 KC SE - Black
Off Road with E-Locker
Big Tow
Captains Chairs with Rockford Fosgate
Utility Bed Package
Bed Extender
Well I must say that it was alot of work. I used bestachess's idea for the amp board to mount all of my components. 3/4" MDF mounted to the bolts on the rear wall. Amps and x overs screwed to the board.
I ran 1/0 powere wire to a d-block (under the JL 500/1) split to two 4 gauge for power. All new speaker wire. New battery terminals under the hood. I need to take pictures under there soon before it gets too dirty.
As for the sub, it is mounted in a combination of a 3/4" MDF box and fiberglass. I wil take more pictures soon. The box has an MDF bottom, top and back with fiberglass sides to match the contours of the center console. I used to stock plastic piece in back with a hole cut in it for the stacked speaker rings to sit proud of it and mount the sub to. I am still tweaking the adjustments on the amp and the HU for sound.
I really like the mb quarts, best sounding speakers I have had so far. As for the fuse box I will get a pic up of it and the other under the hood wiring.
2)and I assume you have the bench seat right, why did you decide to fire it to the back instead of down or up??
3)so did you remove the center storage compartment or fiberglass on top of it?
4)wow much glass/matt did you need (gallons)
5)and finally what postive battery terminal did you use?
6) okay last one promise do you stillhave use of the middle front seat console storage at all
Im so juiced someone did this I was thinking about it for the longest just couldnt fiugre out to get the box in that tight area
1) 10"
2) Captains Chairs. Had to fire it towards the back and down to get it to fit.
3) I gutted the center storage compartment up to the area for the cup holder
4) About 3/4 gallon of resin and enough mat for three layers
5) Knukonceptz for terminals, wire, d-blcok and the big set screw ring terminals
6) See the pictures. There actually is storage left over.
VERY FRIGGIN CREATIVE Im impresssed you see that box copied to readily--lol
on our battery terminal is the stcok fuse holder just hangin?? the way you have it set up, how is it secured??
,and you may want to cover the large screw on the top of the terminal ( I have the knu negative terminal post) and that screw is hot--if your hood ever flexes down (since the metal is very weak) and touches that woudlnt be very nice
