Old 02-23-2005, 08:48 AM   #1 (permalink)
1BadTitan's Avatar
Pic of my Optima Battery and Grounding Set
Heres a pic of my red top with a ground system and platinum terminals. The platinum terminals are attached on the battery post.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 02-23-2005, 08:57 AM   #2 (permalink)
ok, stupid question. Looks great and all, but why the large ground wires?
They are bigger than my house ground wires....
miramar-motorsports is offline   Reply With Quote
Old 02-23-2005, 09:10 AM   #3 (permalink)
I was going to ask why are the ground wires so small. I did lizardking's 0 gage battery-chassis-block ground upgrade on the theory that you are better off with one good ground path rather than numerous smaller guage paths.
The point of upgrading the ground system is that the OEM ground arrangement is inadequate & frequently results in alternator whine in connection with installlation of after market high power stereo systems. Also, some people experience a "ticking" problem caused by arcing with the inadequate factory ground arrangement.
That fuse holder looks nifty.
Old 02-23-2005, 10:12 AM   #4 (permalink)
1BadTitan's Avatar
Thanks.....
1BadTitan
Old 02-23-2005, 11:22 AM   #5 (permalink)
smoketitan's Avatar
so how did you get the stock fuse box to stay on like that?? I see a baterry terminal but how does the fuse box attach
that was the only thing keeping me from buying a optima, which model did you get by the way??
and how did you secure it--use the stock metal brackets??
and was it tall enough to match the ht of the stock battery?
sorry for all the questions Im just excited that this is now possible at the stock battery sucks--it has drained out on me twice already--lol
Old 02-23-2005, 11:42 AM   #6 (permalink)
1BadTitan's Avatar
Ok the platinum terminals have 3 holes for power wires for amps etc. It also has a post for another terminal to mount onto it. Thats how I did the mounting. I got the 34r, 800cca, 950ca and its got the reverse terminals. It is the same height as the stock battery. Yea mine drained twice also.
1BadTitan
Old 02-23-2005, 02:25 PM   #7 (permalink)
smoketitan's Avatar
which terminal is that--that has the extra post on the side
so you attached your amp power line into one of the stock terminal holes,and then latched the fusebox to the side terminal??
am I followin you correctly?
and what fuse box is that at the batteryw itht he voltmeter--do they have one that will fit 1/0 wire??
Old 02-23-2005, 02:44 PM   #8 (permalink)
1BadTitan's Avatar
No I put on this new terminal...Put the amp power in it....Then put the stock terminal onto the post that the platinum supplies.
1BadTitan
Old 02-23-2005, 02:47 PM   #9 (permalink)
1BadTitan's Avatar
The fuseblock with the meter is made by some company called "audiopipe". I liked the display. It has an 80 amp flat blade fuse in it. not the oversize colored fuse but the blade style phoenix gold uses in their big fuse blocks. I'll get some pics of that for you and a close up of the terminal connections.
1BadTitan
Old 02-23-2005, 02:59 PM   #10 (permalink)
Do you have a link for the positive battery terminal?
Old 02-23-2005, 04:08 PM   #11 (permalink)
smoketitan's Avatar
thx ill go lookiing for one
Old 02-23-2005, 08:31 PM   #12 (permalink)
I would like to see more close-up pics too.
titanse05 is offline   Reply With Quote
Old 02-23-2005, 08:43 PM   #13 (permalink)
TitanHauler's Avatar
I have a ticking problem! What's the fix for this and what's the cause????
TitanHauler
2004 Titan KC LE 4X2 "Smoke"
Born: 02/05/04 @ 04:44 - Adopted: 03/07/04
Big Tow Package - Prodigy Controller
PRG/Gagnon 2.5" Leveling Kit
20X8.5" MB Off-Road Gunner 6 Wheels
LT305/55/20 Nitto Terra Grappler A/T Tires
AEM BruteForce CAI
Custom Flowmaster Cat-Back - Resonators Removed
TitanHauler is offline   Reply With Quote
Old 02-23-2005, 09:31 PM   #14 (permalink)
ohiodish's Avatar
same here...ticking
My truck and brother in laws Titan has the same ticking that can be heard at idle.?????
ohiodish is offline   Reply With Quote
Old 02-23-2005, 09:36 PM   #15 (permalink)
smoketitan's Avatar
you have to reground the engine to chasis ground to negative terminal with larger wire (I used 1/0 ga, some have used 4 ga, or you coudl do the multiple points like 1bad did)
it will elimiate it, at least it did in my truck
do search for tcking there is a large thread on it
if you need pics let me knwo and Ill take them for you
