If you are ONLY changing out the radio to an Alpine then the Scosche adapter is the way to go for wiring. The dash kit is also a good idea. I installed an Alpine IVA-D901 in my Titan and used both. If you are upgrading the entire system, adding amps and aftermarket speakers, then you will only use about 2-3 of the stock wires from the harness and it would be just as easy to bypass the connector on the truck side and splice into those wires straight from your stereo. The Scoshe connector allows you to avoid changing any of the factory wiring.
As for alternator whine, I have none. I grounded the stereo to a nearby point on the chasis. I grounded all my amps at the same locatio in the rear of the cab (via a distribution block) and grounded my capacitor in a different location. I also upgraded the negative battery and alternator ground wires to 0 gauge.
