Go Back   Nissan Titan Forums > Titan Discussion > Titan Interior Discussion
User Name
Password
Audio Install...the beginning w/Pics - being discussed at Nissan Titan Forums in the Titan Interior Discussion section.
Old 03-13-2005, 11:56 PM   #31
m95roadster
m95roadster's Avatar
Pics of the HU and subwoofer box. Faceplate done in black plexiglass.
Click image for larger version
ID:	8989  Click image for larger version
ID:	8990  Click image for larger version
2005 Mercedes C-Class
SOLD
2005
Smoke SE Crew Cab
Modifications: a few mods.....
More Pics Here
m95roadster is offline   Reply With Quote
Old 03-13-2005, 11:58 PM   #32
m95roadster
A couple more pics.
ID:	8992  Click image for larger version
Old 03-14-2005, 12:51 AM   #33
smoketitan
smoketitan's Avatar
okay I see three 8's right what are the other two small holes for?
Old 03-14-2005, 01:12 AM   #34
m95roadster
They are for the ports (3").
Old 03-14-2005, 09:46 AM   #35
life_is_good
can you give deminsions of your box please
04 TITAN CC 4x4, 2/4 DROP, 20" DUBS, DEBADGED ALL THE WAY AROUND, STILLEN ROLL PAN, CUSTOM SHAVED TAILGATE, ARMADA PAINTED FRONT AIR DAM, PAINTED MIRRORS, HANDLES, AND WIPER COWL, BRUSHED BILLITT GRILL, CUSTOM 2.5" DUAL EXHAUST, NISMO R-TUNE INTAKE, STILLEN FRONT 14" BIG BRAKES AND MASTER CYLINDER BRACE, TINTED WINDOWS, BLACKOUTS, WINDOW VENTS, LCD, XBOX, CD/MP3 PLAYER, ALPINE TYPE "R" 12 W/500 ALPINE AMP, COMPUSTAR AUTOSTART/ALARM.
life_is_good is offline   Reply With Quote
Old 03-14-2005, 10:38 AM   #36
smoketitan
smoketitan's Avatar
now I see why dual ports though?? why not one big one?? never ported a box so I am asking just for interest sake
what 8's are you going to use??
nice design by the way I like how you tapered the edges,
so what is that about 1.6 or so cu ft??
Old 03-14-2005, 12:23 PM   #37
dman
dman's Avatar
Sometimes you have to use multiple ports to get correct tuning. If done correctly you have to use the correct size and LENGTH for the tuning frequency you are trying to achieve. It may have been the case of 1 single port needed x length that could not be achievable with a single port. If for instance a 4" port needed a 24" length to tune at 30Hz, he would have to put an elbow onto the tubing inside the box which may not be practical. However if he used 2 - 3" ports they may only need to be 10" long to achieve the same tuning and would not require the more complex elbow inside the box. It all just depends on what works best for the speakers, the box design, and the frequency you are tuning to.
The only negative with using 3" ports is that beer cans don't fit quite as well into them when you get pulled over
dman is offline   Reply With Quote
Old 03-14-2005, 12:34 PM   #38
m95roadster
Thanks. Volume is 2.1 cu ft..You can use one or 2 ports or as many as you like. I used 3" ports which is the minimum for this setup. Otherwise you'll get port noise. I didn't want to go bigger because it will eat up volume and I needed every bit. Also, you need to make sure the port is atleast 3" from the wall.
I also rounded over the top edges so when I cover it in vinyl it will look more finished.
Old 03-14-2005, 12:35 PM   #39
m95roadster
Dman,
You are correct on this.
Old 03-14-2005, 12:43 PM   #40
m95roadster
I have to look for my drawing, but at the top of my head; total width:57", height/front:9", height/back:7", depth:13 1/2", bottom/width:21", space over the hump:15" and raised up 3"
Old 03-14-2005, 12:58 PM   #41
smoketitan
smoketitan's Avatar
so what 8's are you using?
Old 03-14-2005, 01:10 PM   #42
m95roadster
Pyramid blue!! JK. I have some XLC woofers that I never used. I'll make use of them temporarily until I find a suitable replacement. If I don't like them I might put my Audiomobile/TC sounds 10's in instead. BTW, what happened to Audiomobile...again?
Old 03-18-2005, 02:46 PM   #43
m95roadster
Sub Box Completion
Here are some pics of the completed box. I used a charcoal colored vinyl and carpet underlayed with some foam.
ID:	9159  Click image for larger version
ID:	9160  Click image for larger version
ID:	9161  Click image for larger version
Old 03-18-2005, 02:52 PM   #44
smoketitan
smoketitan's Avatar
very nice dude!!!!
I like the felt on top very nice touch
whats that white sutff in pic # 4 is that the foam??
Old 03-18-2005, 02:57 PM   #45
m95roadster
very nice dude!!!!
Thanks, yeah that's the foam. I'm working on the grills right now. It will be vinyl wrapped baffles with grey grill cloth.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
