Old 03-06-2006, 01:50 PM   #16 (permalink)
Steamguy's Avatar
Re: Sirius signal cutting out constantly
Originally Posted by Chris M.
You should install the antenna on the roof, not on the dash. The only time the signal will go out in my truck is when I pull into my garage. No obstructions should be present between the antenna and the sirius network My directtv goes out more than my sirius install.
I second that. I had the antenna on the dash before, and had lots of cutouts. Somehow the coatings on the glass seem to attenuate the signal.
I moved it to the outside of the truck and wow, what a difference. There are a couple of spots around where the signal will predictably cut out, and those are by power lines.
Hope this helps.
Steamguy
Old 03-06-2006, 03:41 PM   #17 (permalink)
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
I have the Replay with the antenna sitting on the sunroof cover under the glass. I never have problems with cutout except for the previously mentioned garage and gas stations. It might be that it is not fully plugged in as some have stated or maybe the angle of the antenna on the sindshield is the cause of the problems. I would try getting it outside of the vehicle and see if that helps.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
Old 03-18-2006, 08:47 AM   #18 (permalink)
What does the Nissan Sirius reciever look like and how much with instalation? Thanks
TITANSTEELER is offline   Reply With Quote
Old 04-16-2006, 04:36 PM   #19 (permalink)
I've got the Sirius XACT Visor model radio...the cheapie...It works great. I mounted the exterior antenna through the overhead console and headliner. It works great but I mount the radio on the dash - Got tired of looking through the antenna wire hanging down from the headliner so I put Velcro on an antenna disc and at the front of the dash. I was told with tinted window that the antenna would not work But it works just as well as the exterior antenna. I drive from the SoCal area to Idaho about once a month. The only place the signal is lost for no reason is on I-15 near the Raceway...Nellis AFB is there and I think they jam the signals for security in that area. Otherwise it works fantastic. I move the radio to my company car a Ford Crown Vic and put the antenna on the dash...still works great.
Just my $0.02 --
MDog00 is offline   Reply With Quote
Old 04-16-2006, 07:03 PM   #20 (permalink)
flbigdog's Avatar
I got the oem add on kit from a tt vendor........around $275 shipped.....................dealer installation around $75.........antenna by the mirror.......very rarely drops out and works great with the nav screen...definitely the way to go !
flbigdog is offline   Reply With Quote
