Old 03-19-2005, 12:29 PM   #1 (permalink)
radsterrad's Avatar
Pie Amp?
Just Finished Installing A Pie Amp For Aux Input, Works Great But
I Also Get The Hum When You Accelerate. I Hard Wired It Into The 12 Volt Outlet. I've Read About This In Previous Threads But I'm Curious If Anyone Has Come Up With A Solution.
radsterrad is offline   Reply With Quote
Old 03-19-2005, 01:55 PM   #2 (permalink)
You might want to install a gound loop isolator on it......It'll get the interference out. Only cost about $10-$15.......HTH's.
John C.
TexasTitan04 is offline   Reply With Quote
Old 03-19-2005, 04:51 PM   #3 (permalink)
radsterrad's Avatar
How Did You Wire This Into The Grounding Circuit?
Old 03-19-2005, 06:05 PM   #4 (permalink)
Sammy Sandbag's Avatar
A ground loop isolator installs in the signal lines (RCA's.) Where did you ground your PIE at? Also, what 12V source are you using, the cig plugs? I notice a little alternator noise during quiet songs and high volume, but I've pretty much determined mine is from a bad mini connector. I haven't got around to troubleshooting/fixing it because I'm in the middle of a complete audio overhaul.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 03-20-2005, 06:35 PM   #5 (permalink)
radsterrad's Avatar
I Used The Cig Plug + And - , I'll Try The Ground Loop Isolator, But Do You Know If There Is A Difference Between The Cig Ground Vs. The Chasis Ground.
Old 03-20-2005, 07:56 PM   #6 (permalink)
I couldn't really tell you the difference between the grounds, I would think that it would ground to the chassis at some point, but I could be wrong. You could always try grounding it at a different point, like the crossmember behind the dash.
Old 03-21-2005, 07:04 PM   #7 (permalink)
radsterrad's Avatar
I Picked Up The Ground Loop Isolator And Installed It This Evening,
It Makes Quite A Difference. I Think The Clarity Is Also Much Better
As I'm Using It For My Sattelite Radio. Thanks For The Help!!!
