Old 03-23-2005, 02:16 PM   #1 (permalink)
moore101's Avatar
Arrow Car electrical type question
Guys I hope you can help me. I'm installing a rearview camera on the back of my 5th wheel trailer. I have the camera that came with an 8v AC to DC converter @ .5 amp, it can also run off a 9v battery. Now what would happen if I connect it up to the 12v light system on the trailer? Will it most likely fry the camera? If it may hurt the camera can I add a resistor or something to step down the voltage? What would work best?
Thanks,
Loran
moore101 is offline   Reply With Quote
Old 03-23-2005, 02:40 PM   #2 (permalink)
scr38's Avatar
I think the best solution would be to get a car adapter (DC to DC) unit. Make sure it will provide 8 volts output at .5 amp. These units have a regulated output and would be safe to use with your camera. They are made to plug into a lighter socket, but you could wire it in to 12 volts (you should use a switched source so it would be off when the key is off) You can find these units on eBay for a low price. For example look at this one:
http://cgi.ebay.com/ws/eBayISAPI.dll...753573165&rd=1
Old 03-23-2005, 03:49 PM   #3 (permalink)
moore101's Avatar
Thanks that adapter would work perfect!
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
