Old 03-25-2005, 06:59 AM   #1 (permalink)
radsterrad's Avatar
Sub Box
Are All Sub Boxes Supposed To Have Some Sort Of Sound Deadening
Material Inside? Or Does It Make Much Difference? I Have (1) 10" Sub
Under The Rear Seat And It Sounds Kind Of Punchy With No Material Inside.
radsterrad is offline   Reply With Quote
Old 03-25-2005, 09:30 AM   #2 (permalink)
Most box builders will use some poly fill when the box is a bit to small. The explanation I was given was the it slows down the sound wave and makes the speaker think that it is in a slightly larger enclosure that it really is. The rule of thumb is generally about 1lbs of poly fill per cubic ft of box space. What type of sub do you have and how big is your enclosure? On the subs spec sheet they should give the requirements for the enclosure and they generally will let you know if you need to put fill in the box.
sbo76 is offline   Reply With Quote
Old 03-25-2005, 11:54 AM   #3 (permalink)
radsterrad's Avatar
My Sub Is A 10" Jl The Sub Box Is Made For A Ford Explorer Sport Trac But Fits Nice Under The Rear Seat. I Would Guess Its 1 Cu'
Does Poly Give Ita Rich Sound Or A Punch Sound? Thanks
Old 03-25-2005, 12:58 PM   #4 (permalink)
smoketitan's Avatar
polyfill wont get more spl per say, but it smooth out the bass repsonse since the woofer thinks its in a larger box so thet tones get deeper
if your sub neds more airspace than your box allows then it is a good thing--it smooths out the "boomy"--ness of certaing sub applications
Old 03-25-2005, 03:20 PM   #5 (permalink)
radsterrad's Avatar
I'll Try Some Polyfill If I Can Find It.
Old 03-25-2005, 03:58 PM   #6 (permalink)
radsterrad's Avatar
I Was Also Wondering If A Sub Box Makes A Difference If It's Ported Or Not. Mine Is Not, But I Have Seen Them Ported.
Old 03-28-2005, 10:01 AM   #7 (permalink)
Depending on what the sub is designed for, some times a port can help, sometimes not. With the JL's, I would stick to a smaller sealed enclosure with as much power as you can give it. As far as the polyfill, go to wallmart, target, ect and they will have it. got to the sewing materal section and they will point you to where you need to go.
Old 04-04-2005, 08:57 PM   #8 (permalink)
radsterrad's Avatar
You're Right Not To Port The Jl, Sounded Bad Ported. Thanks For Info On Where To Purchase Material.
Old 04-05-2005, 06:50 PM   #9 (permalink)
Send a message via MSN to Titan_3nE
might be a dumb question but can you make up for less layers of fiberglass with sound deadener ?
Titan_3nE is offline   Reply With Quote
Old 04-05-2005, 07:07 PM   #10 (permalink)
Sammy Sandbag's Avatar
No. The fiberglass in a fiberglass box forms the structure of it. A box that isn't stiff will flex and you'll end up with a terrible sounding box.
-Counsel Yourself
2009 Blizzard Pro-4X
