Old 03-31-2005, 05:07 PM   #1 (permalink)
Send a message via MSN to Titan_3nE
Sound Deadener or Insulation
Anyone know of any affordable or of any good deals on a dynamat substitute ?
Titan_3nE is offline   Reply With Quote
Old 03-31-2005, 05:11 PM   #2 (permalink)
Sammy Sandbag's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
-Counsel Yourself
2009 Blizzard Pro-4X
Old 03-31-2005, 05:20 PM   #3 (permalink)
How much will I need to cover the back wall and flooring, anyone knows ?
Old 03-31-2005, 06:38 PM   #4 (permalink)
Bama334's Avatar
Console Removal & Acoustic Insulation
Check this post,bestachess gives step by step instructions on how to install it, where to buy, and pretty sure he mentions how much he used. BTW this is a cool post! Good luck
2004 Titan LE CC 4X4 Offroad Blizzard
PRG Performance Package
PRG Rear Shackles- PRG Sway Bar End links
True Trac
315 BFG's on factory 17" OR Wheels
Bama334 is offline   Reply With Quote
Old 03-31-2005, 08:21 PM   #5 (permalink)
Kronos1965's Avatar
suitable alternatives to dynamat...
How 'bout aluminum foil and duct tape?
or a 4" thick coating of Krylon spray paint -high temperature kind
maybe sawdust and glue?
Let me know if I've been helpful! Have a good April Fool's Day.
HippieWhore™
Kronos1965 is offline   Reply With Quote
Old 03-31-2005, 08:55 PM   #6 (permalink)
He did a nice job man:
Oh a pic of my truck!
I also added a pic of the game (aux) input faceplate I made.
sound-deadener-insulation-game_plate_front.jpg  sound-deadener-insulation-nissan-tv-006.jpg  sound-deadener-insulation-dscn0100.jpg  sound-deadener-insulation-nissan-tv-005.jpg
Old 04-01-2005, 08:49 AM   #7 (permalink)
Fatmat.com I used 70 sq feet on floor and back wall.
I used fatmat in doors 45 ml thick one layer on outer skin and second layer replacing the plactic sheet behind door panels. Also have for roof but haven't had time to do it yet.
I used their Rattle trap 105 ml thick on floor and back wall.
PS if your doing this by yourself it's a big job and 2-3 days work.
Most all instructions on panel and consol removal are on TT do a search.
Disconnect your battery before you start or you'll set off several codes.
Old 04-01-2005, 01:39 PM   #8 (permalink)
Thanks for the tips greg w, I got a link above (Ebay, gotto to love it) for 100 sq/ft for 99.00, I thnk I will get that:
Anyone heard those Diamond Audio CM310D2 10" before, thinking about getting two for under the seat.
Old 04-02-2005, 06:23 AM   #9 (permalink)
Voodoo's Avatar
dynamat extreme for $99
this stuff is the best imo and I wouldnt mess around with anything else....have my whole car done with this back in 2001 and have no complaints
Voodoo is offline   Reply With Quote
Old 04-02-2005, 09:08 AM   #10 (permalink)
rcantu's Avatar
I'm using Raamatt. It's day 2 and I'm just too slow.
I finally have the rear doors dampened and now working on the fronts. The fronts are huge. I've doubled up on the mat for the front cause I have RE XXX 6.5 going in there. Also I have Ensolite foam that I'm covering the entire truck for acoustical damping.
pics of the Titan
Old 04-02-2005, 09:50 AM   #11 (permalink)
Be careful that the cable that loops around at the door latch is secured. I brought down my rear windows and the left back door came open. I hadn't gotten it back into the upper clip and the window caught it coming down. After I closed the door I couldn't open it so I had to re-remove the door panel with it closed. Luck I was only going slow when it happened and a block from the house.
Old 04-02-2005, 10:56 AM   #12 (permalink)
How much waz the Raamat ?
Old 04-02-2005, 11:33 AM   #13 (permalink)
rcantu's Avatar
thanks Greg W for the tip. I already sealed the doors but will test it before I put the panels back on.
Titan_3nE I paid $89 a roll of 62.5 sq ft. I never tried Fatmat but Raamatt is very popular on the car audio forums. It's very comparable to Dynamat Extreme from what others say. I've never used dynamate. I have 2 rolls and a ton of ensolite foam. I bought a roll of aluminum sheeting (called flashing) to cover the larger holes of the door panels so the mat has something to stick too instead of just open air. Takes me longer to cut but worthwhile.
I'll be taking out the seats maybe tomorrow.
pics of the Titan
Old 04-03-2005, 05:35 PM   #14 (permalink)
cjr02's Avatar
How are you attaching the flashing to the door panels?
2007.5 Chevrolet 3500HD Z71 Duramax
*******2004 4X2 SE CC ******SOLD**********
PRG leveling kit, BFG 315/70/17 A/T KO's on SSC chrome alloy wheels, Body color XE front + rear bumpers, One piece billet grille, Black XE door handles + mirror covers, Katzkins 2 tone leather interior, debadged exterior, Silverstar Hi/lo beams, Retrax retractable bed cover, front tint, round tube hitch, Audiovox 13.3" flip down monitor in custom console, 12" pioneer sub under front seat, 6.5" Kove audio components, Amp rack, Hifonics amps, Audiocontrol 6XS crossover, Pure sine wave power inverter, PS2, Optima yellow top battery, 0/1G power/ground, Audiocontrol LC6 line driver, Elemental Designs sound deadening.
cjr02 is offline   Reply With Quote
Old 04-03-2005, 05:50 PM   #15 (permalink)
I had the same idea of using the flashing, but instead I just put two layers, one with the sticking side facing inside and one facing outside. The two layers stick together and a fairly rigid.
