Old 04-14-2005, 02:34 PM   #1 (permalink)
Where did you get the wire harness
NN03 and NN03R?
Also, since I do NOT have the RF system, do I need the LOC?
Thanks,
Yomama -
2005 4x4 Canteen Crewcab SE with BT, OR, Utiltrak and Popular Package.
Ziebart rust proofing
A.R.E. Z series topper
Myron and Davis DVD for the kiddies, DDX7015 for me Kenwood amp and lightning amp on 8" polk sub. Audiovox remote starter (with satellite link)
Zoomers (No Drone) exhaust
AEM intake
Stillen Headers
2002 Hyundai Santa FE (The wifes)
2001 Polaris 700 Twin ATV
1996 28' Bayliner Cierra Sun
http://www.yomama.net
Yomama is offline   Reply With Quote
Old 04-14-2005, 05:07 PM   #2 (permalink)
If you plan on keeping the Popular Package HU, then, yes, you will need LOCs to connect to an external amp. The Nissan HU uses a balanced output for the speaker output, that is, one line is not ground. A number of amps have a hi-level input but a lot of these use a common line for the speaker input - one line of each of the speaker outputs go to a common point on the amp hi-level input. This is not good when the HU outputs are balanced - output transistors have been know to destroy themselves when connected this way. Therefore, one needs an LOC because it will accept a balanced input.
The connectors are available at a number of places. Most auto audio shops will have them and there are a lot of sources on-line. Do a Google search on the wire harness part number.
Old 04-14-2005, 06:13 PM   #3 (permalink)
This connector plugs into the back of the head unit:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
This connector plugs into the harness:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 04-16-2005, 06:19 AM   #4 (permalink)
Snap's Avatar
Location: Northern California where the girls are warmer...
Do these harnesses work with the RF system as well? Thanks!!
"Well done is better than well said" -Ben Franklin
Snap is offline   Reply With Quote
Old 04-20-2005, 11:09 AM   #5 (permalink)
Yes, I think so. I used the Scosche connectors, which are apparently in short supply at the moment. Keep in mind that the RF system has an external amplifier. If you are intending to drive speakers using aftermarket amp(s) through the OEM speaker wires, you need to make a bypass harness for the RF amp per eakes' previously posted instructions. Alternatively, you can just pull new speaker wires from your aftermarket amp(s).
