What is the little white ball with the wire coming out of it?
I think that's his radio antenna. It has one of those balls on it.
__________________ 2008 LE Crew Cab 4x4 Majestic Blue Bridgestone Dueler A/T Revo 275/60TR20; Nissan OEM Bug Deflector; Magnaflow 18" muffler (12258); Wade In Channel Vent Visors; Retrax Tonneau Cover...recently replaced by an A.R.E. LSII tonneau cover; Factory Sirius Satellite Radio (XM to Sirius swap); Autopage Remote Starter; Bosch ICON Wiper Blades; Whelen Dual-Talon Blue/Blue LED Emergency Light mounted on windshield; Signal Vehicle Products DL15-6W-1K Blue/Blue LED Emergency Lights mounted in rear window; 2 Galls Single Head Blue/Blue LED Emergency Lights mounted in the upper corners of the bumper opening
2004 LE Crew Cab 4X4; Red Brawn...TRADED on 7/11/07
I'm interested to know if you have reception problems due to this location. I have the same thing, dealer installed and my signal cuts out CONSTANTLY while driving through town, or driving along wooded roads. I had XM in one of my previous cars with the antenna mounted inside on the center of the dash and it only cut out going under underpasses. It's a major PITA.
Is that the new OEM install location? I like mine on the back glass much better...less obtrusive, but mine still seems overly large compared to the little Terk ones.
I'm sorry to see the choice of antenna your installer made. It is far more obtrusive than the micro antennas that came with my SkiFi 2 and Roady2 XM radios. They are less than two inches square and the thin cable easily fitted under the gasket of the third brake light. No leaks and flawless reception on my trip from Washington State to here in Virginia.
Your antenna does have the advantage of not needing to run a cable, however small, from the outside to the inside.
Ralph Featherstone
'05 Titan SE KC 4X2
Has anyone installed the new Sirius S.I.G.M.A. (Sirius Interior Glass Mounted Antenna)Antenna? I guess it adhere's to the inside of your windshield close to where your rear view mirror is attached. I was wondering what the signal strength was like.
I installed a Sirius SIGMA along with the OEM receiver. Got the stuff from Jamie at TitanParts 247. Signal strength and sound quality are excellent. About the only place I loose it is under a metal structure thats fairly close to the antenna, such as at an ATM or when driving into my garage (double skin steel door). Driving under a bridge seldom affects it.
The SIGMA cannot be seen from outside the truck. Although it's not a "micro" antenna, it's size, shape and location make it just about "invisible" from the inside.
Jim in NH Copper LE CC (mine)
Born 2/25/04. 4 WD, Big Tow, Nissan Hood Protector, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, OEM Sirius & Sigma antenna, K&N drop-in. Galaxy SE KC (son's)
Born 5/10/04. 4 WD, Big Tow, Popular Package w/captains, Utility Bed, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, K&N drop-in.
Marcus . . . yep that was a SIGMA antenna. Jamie's price for antenna/receiver/brackets is $346.80 (plus $10 for UPS). The antenna piece of that was $62.90. I didn't use the brackets - I installed the receiver on the knee bolster under the steering column.
So was that $400 holiday pay before or after taxes? If you order from Jamie, you might call just to be sure he's sending the sigma antenna vs. a roof-mount one.
I keep going back and forth, I use to love my Sat. radio in my RSX-S. But I use to live in a small small town with a few country stations and one oldies station. Now that I live close to memphis, I get a good rock station...
But I hate commercials, spent the whole day in my uncles Silverado listening to XM, no thanks, they didnt have a rock station like Sirius. It was either too light to too heavy, Octane is about all I listened to in my RSX...
I have XM installed stock, and the rear glass antenna. My trial isnt working. I called XM and they sent out a refresh signal, and i left it on channel 1 for an hour, but nothing....
Any tips? Should i call service now and have them deal with it?
thanks
puv
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
I just bought the xm receiver with the same antenna as the one pictured above and I guess the same one as Th1rd3y3 has and the reception is very bad!!! It cuts out all the time even under a clear sky!! I am clalling Jamie a the Nissan dealer to see if he will exchange the antenna for the other style.
David Roth
White KC SE 4X2
Great Truck!!
