I used a needle-nose pliers, or a small screw driver to just pop the pin out. Be careful not to lose it though.
If your wondering how to replace the handle that is really a trick that turned out to be easier then getting it off. Hold the window handle with one hand, and place the pin back into the proper slot of the window handle with the other hand, or the needle nosed pliers. Then just push it back onto the window gear and it will click into place. It's that simple!
