Old 08-29-2005, 12:06 PM   #1 (permalink)
Flight Test's Avatar
Homemade dead pedal...
I decided to make my own dead pedal out of a 7"x3"x 0.25" piece of 2024-T3 aluminum. I wanted something a little firmer than the stock pad. I drilled five (5) 5/32" holes in a cross pattern, countersunk. I removed the stick-on ribbed pad and mounted the plate where I wanted it. I drilled two pilot holes into the metal floor with a 0.087" bit and secured two of the five sheet metal screws. The other three screwed into the thick padding. I know it does not look as pretty as the aftermarket stuff, but it serves my purpose. I will post pics later.
Joe
God Bless the USA!
2005 LE KC 4x2
A15/Steel, W07, N94, L92.
Hellwig Anti-Sway Bar
******* Industries: SS Door Sill Trim, Chrome Tailgate Trim
LED tail/brake lights
OEM Bug Deflector & Step Rails
Armada Front Air Dam
Born 4/2005
Brought home 7/7/2005
2000 Corvette Coupe
Flight Test is offline   Reply With Quote
Old 08-29-2005, 03:20 PM   #2 (permalink)
rjspitz's Avatar
I'd like to see pics. I've wanted to do this on my truck, I'm just a bit scared to drill into the floor. The stock dead-pedal is very uncomfortable.
Old 08-29-2005, 05:56 PM   #3 (permalink)
Pics are up. I like the firmer feel. The plate offers more surface area to rest my foot. I used the old ribbed pad as a right foot heel guard. A couple of dots of hot glue, we'll see how it holds up.
Old 08-29-2005, 06:04 PM   #4 (permalink)
SWTXTITAN's Avatar
I think my left foot rests on my mat
Maybe im just wierd like that
" You want me? F%*&in come and find me, I'll be waiting with a gun and a pack of sandwiches " Radiohead
"Me I'm standing right down here in Texas, I know that's where I was always meant to be" Pat Green
SWTXTITAN is offline   Reply With Quote
Old 08-29-2005, 06:07 PM   #5 (permalink)
If you do want it pretty invest $6 in a tub of Mother's Mag & Aluminium polish... I gaurantee it will come out show quality after a little elbow grease.
-Cyrus
Vyrus is offline   Reply With Quote
Old 08-29-2005, 06:12 PM   #6 (permalink)
TOK
TOK's Avatar
Excellent idea. Since a machined finish is out, I think I'd put a little extra piece of carpet over it. Big piece of velcro might be perfect to hold it firm yet still give access to screws.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline   Reply With Quote
Old 08-29-2005, 07:46 PM   #7 (permalink)
rjspitz's Avatar
Or hit it with some scotch-brite for the brushed look. You can achieve a like-machined look if you are carefull and only go in the same direction with the scotch-brite.
Looks good. Thanks for the pics.
Old 08-29-2005, 09:06 PM   #8 (permalink)
RockyMtnTitan's Avatar
I used a drill with sander attachment, using 400 grit paper (I think) to get this effect on my custom Volant lid I made.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 08-30-2005, 05:41 AM   #9 (permalink)
Thanks for the cosmetic suggestions.
Joe
God Bless the USA!
2005 LE KC 4x2
Born 4/2005
2000 Corvette Coupe
Old 09-15-2005, 05:06 PM   #10 (permalink)
Nice work, might also suggest screws that are not rounded out. Kinda makes it look like a home job ...
SmokenTitan is offline   Reply With Quote
Old 09-15-2005, 06:55 PM   #11 (permalink)
Thanks, I did buy new screws
Joe
God Bless the USA!
2005 LE KC 4x2
Born 4/2005
2000 Corvette Coupe
Old 09-15-2005, 07:49 PM   #12 (permalink)
Dead pedal, huh. What happened to the lost art of two-footin' it? After all, We all have free lifetime brakes. Nothing's more enjoyable than irritating the people behind you by ever so gently illuminating your brakelights every 5 seconds.
Silver 04, Kingcab,Magnaflo,K-N drop-in,17" steel wheels, bald tires
Chip Boehner is offline   Reply With Quote
